1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: No motor ui in pydm
To: tech-talk <[email protected]>
Date: Mon, 26 May 2025 17:04:18 +0800 (CST)
Hi all,
       Now we want to use pydm OPI and bluesky.
       There are some question when we create the UI.
       the motor UI always looked the same no matter what OPI tools we uesd, medm/edm/css.
       But we did not find the old motor ui file in pydm.
        Do we need to recreate a motor ui ourself?  if so, the ui would be not same again, it is a pity.
        And why no convert file in pydm?
        I am not familiar with pydm. Could someone give me some advice.
Lynn
Prev: RE: Diagnosing and overcoming GigE camera freezes Abdalla Ahmad via Tech-talk
Next: Re: String manipulation from IOC Output Dariush Hampai via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Prev: Re: Installing .req files via DB vs. REQ? Johnson, Andrew N. via Tech-talk
Next: Enable or select records Dr. Simon Friederich via Tech-talk
