Hi Lewis,
There is no one “right way”, different sites can and do install them in different places depending on how they configure their IOCs; the APS accelerator IOCs use a few different approaches, depending on who
created that IOC. Sometimes the .req files are placed directly in the IOC’s iocBoot directory, sometimes in the iocBoot/ioc… directory, or they might be loaded directly from a support module — there are iocsh commands provided by autosave which tell the code
where to go looking for them, and they must match.
The EPICS build system makes it easy to add build rules to install new file types from a Makefile, there are comments giving instructions in the Base/configure/CONFIG_FILE_TYPES file. For example, if the REQ
files should be installed into $(INSTALL_LOCATION)/req adding these 2 lines to the main body of the Makefile which sets REQ would create the appropriate rule automatically:
FILE_TYPE += REQ
INSTALL_REQ = $(INSTALL_LOCAION)/req
You don’t have to put those lines in the Makefile itself though, they could go in your Base/CONFIG_SITE file if you want them to apply to all IOCs; a support module could set them in an exported cfg/CONFIG_something
file, or they could go in the IOC area’s configure/CONFIG_SITE file for example.
HTH,
- Andrew
Complexity comes for free, Simplicity you have to work for.
On 5/23/25, 6:01 PM, "Tech-talk" <tech-talk-bounces at aps.anl.gov> wrote:
- Installing .req files via DB vs. REQ? J. Lewis Muir via Tech-talk
RE: AreaDetector Monthly Collaboration Meetings and project owners Pearson, Matthew via Tech-talk
Eaton UPS Network-M3 boj via Tech-talk
<2025>
No motor ui in pydm l123173 via Tech-talk
<2025>
ANJ, 28 May 2025 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
