1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: Communicating with Bechoff I/O through EPICS
From: Sibylle Ducroizé via Tech-talk <[email protected]>
To: [email protected]
Date: Wed, 28 May 2025 13:23:34 +0200
Hello,
I have just started working on an update of the control system software for an accelerator.
I am still trying out different configurations and learning how to use EPICS. I followed the tutorial of the EPICS documentation so I know basic information about IOCs and have common support modules installed (asyn, calc, streamDevice,...)
I would like to communicate with Beckhoff I/O terminals, both as a way to learn EPICS and to try out configurations for the final project. I have tried following this advice from a previous tech-talk question from 2018.
So far I have installed etherlab's ethercat master and I've tried installing PSI's ecmc which needs e3 to build. Unfortunately, e3-build fails to install epics base so I didn't get very far...I am on ubuntu which might be the problem.
My questions :
1. Are there maintained EPICS drivers for communicating with Beckhoff I/O ?
    1.a. If so, is ecmc a good option ? (As it depends on e3, meant to run on centOS which is obsolete)
    1.b. Are there other similar alternatives ?
2. Should I basically write my own drivers ?
    1.a. An advice / general approach for me to follow as I am new to EPICS ?
Sibylle
Re: Communicating with Bechoff I/O through EPICS Jörn Dreyer via Tech-talk
RE: Communicating with Bechoff I/O through EPICS Žiga Oven via Tech-talk
Prev: RE: Eaton UPS Network-M3 Freddie Akeroyd - STFC UKRI via Tech-talk
Next: autosave: pass-0 and pass-1 with a custom device support Andrea Celentano via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Prev: Re: Eaton UPS Network-M3 boj via Tech-talk
Next: Re: Communicating with Bechoff I/O through EPICS Jörn Dreyer via Tech-talk
