1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: Problem with Newport CONEX-AGAP FTDI device on Linux
To: EPICS tech-talk <[email protected]>
Date: Fri, 20 Jun 2025 16:51:56 +0000
Folks,
I have an older Newport-CONEX-AGP controller that works fine on Linux.
https://www.newport.com/f/agilis-piezo-linear-stage-with-conex-controller
The device has a USB interface and uses FTDI.  When I plug in the device on my RHEL 9 machine I see these messages in dmesg:
[62289.315988] usb 1-4: new full-speed USB device number 10 using xhci_hcd
[62289.447505] usb 1-4: New USB device found, idVendor=104d, idProduct=3006, bcdDevice= 6.00
[62289.447514] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[62289.447518] usb 1-4: Product: CONEX-AGP
[62289.447520] usb 1-4: Manufacturer: Newport
[62289.447522] usb 1-4: SerialNumber: A6UJN7YS
[62289.450490] ftdi_sio 1-4:1.0: FTDI USB Serial Device converter detected
[62289.450536] usb 1-4: Detected FT232R
[62289.451085] usb 1-4: FTDI USB Serial Device converter now attached to ttyUSB0
The device is now available on /dev/ttyUSB0.
I expected to be able to do the same thing with a newer CONEX-AGAP controller.
https://www.newport.com/f/conex-piezo-absolute-positioning-mirror-mount
However, when I plug in the device on my RHEL 9 machine I see these messages in dmesg:
[62360.327898] ftdi_sio ttyUSB0: FTDI USB Serial Device converter now disconnected from ttyUSB0
[62360.327934] ftdi_sio 1-4:1.0: device disconnected
[62363.524320] usb 1-4: new full-speed USB device number 11 using xhci_hcd
[62363.655966] usb 1-4: New USB device found, idVendor=104d, idProduct=3008, bcdDevice= 6.00
[62363.655975] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[62363.655978] usb 1-4: Product: CONEX-AGAP
[62363.655980] usb 1-4: Manufacturer: Newport
[62363.655982] usb 1-4: SerialNumber: A694ND5H
Note that I do not get the messages about ftdi_sio detected or the message about attaching to ttyUSBx.
The new CONEX-AGAP works fine on Windows, where it appears as a COM port.  I can configure the COM port with EPICS:
drvAsynSerialPortConfigure("serial1", "COM5", 0, 0, 0)
asynOctetSetInputEos("serial1",0,"\r\n")
asynOctetSetOutputEos("serial1",0,"\r\n")
asynSetOption("serial1",0,"baud","921600")
asynSetOption("serial1",0,"bits","8")
asynSetOption("serial1",0,"stop","1")
asynSetOption("serial1",0,"parity","none")
asynSetOption("serial1",0,"clocal","Y")
asynSetOption("serial1",0,"crtscts","N")
Given the behavior on Windows, I think the CONEX-AGAP is also an FTDI device.  But if so, then why is Linux not recognizing it as such?
Re: Problem with Newport CONEX-AGAP FTDI device on Linux James P. Withrow via Tech-talk
Re: Problem with Newport CONEX-AGAP FTDI device on Linux Dmitry Yu. Bolkhovityanov via Tech-talk
Prev: Some questions about CaLab Dariush Hampai via Tech-talk
Next: Re: Problem with Newport CONEX-AGAP FTDI device on Linux James P. Withrow via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Prev: Re: [EXTERNAL] Some questions about CaLab Dariush Hampai via Tech-talk
