1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025
Subject: Re: Problem with Newport CONEX-AGAP FTDI device on Linux
From: "James P. Withrow via Tech-talk" <tech-talk at aps.anl.gov>
To: Mark Rivers <rivers at cars.uchicago.edu>
Cc: tech-talk EPICS <tech-talk at aps.anl.gov>
Date: Fri, 20 Jun 2025 17:18:51 +0000
Mark -
It looks like the issue may be that the VID/PID pair (particularly the PID) may not be included in the currently running ftdi_sio driver.
A quick Google search turned up this incantation, which may be helpful:
echo "<VID> <PID>" >  /sys/bus/usb-serial/drivers/ftdi_sio/new_id
Untested, as I’m out of the office, but hopefully this may point you in the correct direction.
-Jim Withrow
Sent from my iPhone
On Jun 20, 2025, at 11:52, Mark Rivers via Tech-talk <tech-talk at aps.anl.gov> wrote:
62363.524320] usb 1-4: new full-speed USB device number 11 using xhci_hcd
[62363.655966] usb 1-4: New USB device found, idVendor=104d, idProduct=3008, bcdDevice= 6.00
[62363.655975] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[62363.655978] usb 1-4: Product: CONEX-AGAP
[62363.655980] usb 1-4: Manufacturer: Newport
[62363.655982] usb 1-4: SerialNumber: A694ND5H
RE: Problem with Newport CONEX-AGAP FTDI device on Linux Mark Rivers via Tech-talk
Prev: Problem with Newport CONEX-AGAP FTDI device on Linux Mark Rivers via Tech-talk
Next: Re: Problem with Newport CONEX-AGAP FTDI device on Linux Dmitry Yu. Bolkhovityanov via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025
Next: RE: Problem with Newport CONEX-AGAP FTDI device on Linux Mark Rivers via Tech-talk
ANJ, 20 Jun 2025 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
