1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025
Subject: RE: Problem with Newport CONEX-AGAP FTDI device on Linux
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: "James P. Withrow" <jwithrow at cornell.edu>
Cc: Christofanis Skordas <skordasc at uchicago.edu>, tech-talk EPICS <tech-talk at aps.anl.gov>
Date: Fri, 20 Jun 2025 19:02:31 +0000
Folks,
Thanks for the quick replies.  The problem is that CONEX-AGP is known to the RHEL9 Linux kernel, but the CONEX-AGAP is not.
I was able to get it working by running these commands:
modprobe ftdi_sio
echo 104d 3008 > /sys/bus/usb-serial/drivers/ftdi_sio/newid
When I plugged in the CONEG-AGAP /dev/ttyUSB0 was created.  When I plugged in a second CONEX-AGAP /dev/ttyUSB1 was created.
However, that solution is temporary and does not survive a reboot.
The permanent solution was to create these 2 files:
  • /etc/modules-load.d/ftdi_sio.conf containing the following single line:
ftdi_sio
  • /etc/udev/rules.d /99-conex-agap.rules containing these 2 lines:
ACTION="" ATTRS{idVendor}=="104d", ATTRS{idProduct}=="3008", RUN+="/bin/sh -c 'echo 104d 3008 > /sys/bus/usb-serial/drivers/ftdi_sio/new_id'"
SUBSYSTEM=="tty", ATTRS{idVendor}=="104d", ATTRS{idProduct}=="3008", SYMLINK+="conex_agap", MODE="0666"
Thanks again,
Sent: Friday, June 20, 2025 12:19 PM
To: Mark Rivers <rivers at cars.uchicago.edu>
Cc: tech-talk EPICS <tech-talk at aps.anl.gov>
Subject: Re: Problem with Newport CONEX-AGAP FTDI device on Linux
Mark -
It looks like the issue may be that the VID/PID pair (particularly the PID) may not be included in the currently running ftdi_sio driver.
A quick Google search turned up this incantation, which may be helpful:
echo "<VID> <PID>" >  /sys/bus/usb-serial/drivers/ftdi_sio/new_id
Untested, as I’m out of the office, but hopefully this may point you in the correct direction.
-Jim Withrow
Sent from my iPhone
On Jun 20, 2025, at 11:52, Mark Rivers via Tech-talk <tech-talk at aps.anl.gov> wrote:
62363.524320] usb 1-4: new full-speed USB device number 11 using xhci_hcd
[62363.655966] usb 1-4: New USB device found, idVendor=104d, idProduct=3008, bcdDevice= 6.00
[62363.655975] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[62363.655978] usb 1-4: Product: CONEX-AGAP
[62363.655980] usb 1-4: Manufacturer: Newport
[62363.655982] usb 1-4: SerialNumber: A694ND5H
Problem with Newport CONEX-AGAP FTDI device on Linux Mark Rivers via Tech-talk
Re: Problem with Newport CONEX-AGAP FTDI device on Linux James P. Withrow via Tech-talk
Prev: Re: Problem with Newport CONEX-AGAP FTDI device on Linux Dmitry Yu. Bolkhovityanov via Tech-talk
Next: Re: [EXTERNAL] Some questions about CaLab Dariush Hampai via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025
Prev: Re: Problem with Newport CONEX-AGAP FTDI device on Linux James P. Withrow via Tech-talk
Next: Re: Problem with Newport CONEX-AGAP FTDI device on Linux Dmitry Yu. Bolkhovityanov via Tech-talk
ANJ, 20 Jun 2025 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
