1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025
Subject: Re: Generation of state diagram documentation from SNL
From: "Hao, Hao via Tech-talk" <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Tue, 29 Jul 2025 21:43:52 +0000
Hi, Ed,
TDM (https://github.com/diverhao/tdm/releases/tag/v2507) has a “Seq Graph” tool to visualize and run a state machine in the frontend. This tool roughly follows the snl grammar to define the state machine, such as ss/state/when(). The logic must be written in _javascript_. It provides several functions to read/write PVs. For example, await delay(2) to delay 2 seconds, value_of(“pv_name”) to obtain the value, caput(“pv_name”, 33) to PUT a value, connect(“pv_name1”, “pv_name2”) to connect and monitor the PVs.
You can also visualize an existing C-like snl code using the “Emulation mode”, but you cannot run the code.
How to run a _javascript_ state machine code:
https://github.com/diverhao/misc/blob/main/tdm/run-state-machine.gif
How to visualize a SNL code:
https://github.com/diverhao/misc/blob/main/tdm/visualize-snl-state-machine.gif
The following code is a simple _javascript_ traffic light state machine:
// global variables must be written in global.xxx
global.R = 0;
global.Y = 1;
global.G = 2;
global.lights = [
    "traffic:red_light",
    "traffic:yellow_light",
    "traffic:green_light"
connect(...global.lights);
global.red_time = 3.0;
global.red_yellow_time = 1.0;
global.green_time = 4.0;
global.yellow_time = 1.0;
ss light {
// no code allowed here
state red {
        entry {
            caput(global.lights[global.R], 1);
            caput(global.lights[global.Y], 0);
            caput(global.lights[global.G], 0);
        when (await delay(global.red_time)) {
            print("switch to red-yellow light");
        } state red_yellow
    state red_yellow {
        entry {
            caput(global.lights[global.Y], 1);
        when (await delay(global.red_yellow_time)) {
            print("switch to green light");
        } state green
    state green {
        entry {
            caput(global.lights[global.R],0);
            caput(global.lights[global.Y],0);
            caput(global.lights[global.G],1);
        when (await delay(global.green_time)) {
            print("switch to yellow light");
        } state yellow
    state yellow {
        entry {
            caput(global.lights[global.Y],1);
            caput(global.lights[global.G],0);
        when (await delay(global.yellow_time)) {
            print("switch to red light");
        } state red
Best,
Hao
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Ed Janke via Tech-talk <tech-talk at aps.anl.gov>
Date: Thursday, June 26, 2025 at 8:56
PM
To: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Subject: [EXTERNAL] Generation of state diagram documentation from SNL
Hello! Does anyone know if there is software out there that can parse the SNL in an EPICS Sequence file to generate a state diagram for every state set? I was considering doing this by hand but figured I would ask the greater community in case
Hello!
I was considering doing this by hand but figured I would ask the greater community in case this already exists.
Ed Janke
Generation of state diagram documentation from SNL Ed Janke via Tech-talk
Prev: 回覆: Value of Renishaw absolute encoder exceeds its maximum Chiang, Liang-Chih [江良志] via Tech-talk
Next: RE: Using AD plugins on asyn port Abdalla Ahmad via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025
Prev: Re: Generation of state diagram documentation from SNL Ed Janke via Tech-talk
Next: Re: Generation of state diagram documentation from SNL DESMARCHELIER Gabriel via Tech-talk
ANJ, 30 Jul 2025 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
