Hi Dariush,
I think you have the order of your dbd files wrong. They should be in this order:
mdrive_1IOC_DBD += asyn.dbd
mdrive_1IOC_DBD += drvAsynIPPort.dbd
mdrive_1IOC_DBD += stream-base.dbd
Is stream-base.dbd part of the StreamDevice module, or is that something local to your site? The files you listed did not include base.dbd, which should come first. So I think it should really be:
mdrive_1IOC_DBD += base.dbd
mdrive_1IOC_DBD += stream.dbd
-----Original Message-----
From: Dariush Hampai <dariush.hampai at lnf.infn.it>
Sent: Thursday, September 18, 2025 10:21 AM
To: tech-talk at aps.anl.gov; Mark Rivers <rivers at cars.uchicago.edu>
Subject: Problem with drvAsynIPPortConfigure
hi Community,
I'm writing an IOC for industrial motor driver:
I prepare the IOC, in particular:
1) in the configure/RELASE there is
SUPPORT=$(EPICS_BASE)/synApps_6_3/support
ASYN=$(SUPPORT)/asyn-R4-44-2
STREAM=$(SUPPORT)/StreamDevice-2-8-24
EPICS_BASE = /home/xlabsrv2/epics
2) in the mdrive_1IOC/src/Makefile there is mdrive_1IOC_DBD += stream-base.dbd mdrive_1IOC_DBD += drvAsynIPPort.dbd mdrive_1IOC_DBD += asyn.dbd
mdrive_1IOC_LIBS += stream
mdrive_1IOC_LIBS += asyn
3) in the mdrive_1IOC/Db/Makefile there is DB += mdrive_1IOC.proto DB += mdrive_1IOC.db DB += mdrive_1IOC.val
4) in the mdrive_1IOC/Db/mdrive_1IOC.val there is file db/mdrive_1IOC.db {
pattern { card, axis, ASYNPORT, MOT, EGU, homing, MRES, direct }
{ 1, 1 , "ip_x", "mdrive_x", mm, 1, 411, + } }
5) in the st.cmd there is
epicsEnvSet ("STREAM_PROTOCOL_PATH", "${TOP}/db") epicsEnvSet ("PORT_mdrive_x", "ip_x")
drvAsynIPPortConfigure($(PORT_mdrive_x), "100.100.0.23:503")
asynOctetSetInputEos($(PORT_mdrive_x),0,"\n\r")
asynOctetSetOutputEos($(PORT_mdrive_x),0,"\n\r")
asynSetTraceMask($(PORT_mdrive_x),-1,0x9);
asynSetTraceIOMask($(PORT_mdrive_x),-1,0x2)
These are the configurations. After make (all is ok), executing the st.cmd I receive the following error
[xlabsrv2@xlabsrv2 iocmdrive_1IOC]$ ./st.cmd #!../../bin/linux-x86_64/mdrive_1IOC
< envPaths
epicsEnvSet("IOC","iocmdrive_1IOC")
epicsEnvSet("TOP","/home/xlabsrv2/epics/IOCs/mdrive_1IOC")
epicsEnvSet("SUPPORT","/home/xlabsrv2/epics/synApps_6_3/support")
epicsEnvSet("ASYN","/home/xlabsrv2/epics/synApps_6_3/support/asyn-R4-44-2")
epicsEnvSet("STREAM","/home/xlabsrv2/epics/synApps_6_3/support/StreamDevice-2-8-24")
epicsEnvSet("EPICS_BASE","/home/xlabsrv2/epics")
cd "/home/xlabsrv2/epics/IOCs/mdrive_1IOC"
"/home/xlabsrv2/epics/IOCs/mdrive_1IOC/db")
#X Axis
drvAsynIPPortConfigure(ip_x, "100.100.0.23:503") ERROR st.cmd line 36: Command drvAsynIPPortConfigure not found.
asynOctetSetInputEos(ip_x,0,"\n\r")
ERROR st.cmd line 37: Command asynOctetSetInputEos not found.
asynOctetSetOutputEos(ip_x,0,"\n\r")
ERROR st.cmd line 38: Command asynOctetSetOutputEos not found.
asynSetTraceMask(ip_x,-1,0x9);
ERROR st.cmd line 40: Command asynSetTraceMask not found.
asynSetTraceIOMask(ip_x,-1,0x2)
ERROR st.cmd line 41: Command asynSetTraceIOMask not found.
dbLoadDatabase "dbd/mdrive_1IOC.dbd"
mdrive_1IOC_registerRecordDeviceDriver pdbbase ## Load record instances
#dbLoadRecords("db/mdrive_1IOC.db","user=xlabsrv2")
dbLoadTemplate("db/mdrive_1IOC.val")
dbLoadTemplate: Too many values given, line 14.
cd "/home/xlabsrv2/epics/IOCs/mdrive_1IOC/iocBoot/iocmdrive_1IOC"
iocInit
Starting iocInit
## EPICS R7.0.8.2-DEV
## Rev. R7.0.8.1-142-g144f9756eac4e800f18d
## Rev. Date Git: 2025-02-05 10:16:16 -0600 ############################################################################
2025/09/18 16:04:01.785392 _main_ Cannot find a bus named 'ip_x' for 'mdrive_x:model'
2025/09/18 16:04:01.785498 _main_ mdrive_x:model: Can't attach to bus ip_x 0
2025/09/18 16:04:01.785517 _main_ mdrive_x:model: Record initialization failed
## Start any sequence programs
#seq sncxxx,"user=xlabsrv2"
epics>
searching in previous threads I found missing the "drvAsynIPPort.dbd" in src/Makefile, but I already put it. Moreover I use "make clean all", and (to be sure) in this case I also remove db, dbd, and lib folders to restart with a clean make
where ma I wrong?
thank you in advance!!!
Dariush
p.s.: all other IOCs using drvAsynIPPortConfigure working properly...
Dr. Dariush Hampai, PhD
INFN - LNF
X-Lab Frascati
Via E. Fermi, 54 (ex 40)
I-00044 Frascati (RM)
Italy
Mail Address:
XLab-Frascati
LNF-INFN
Casella Postale 13
Frascati (RM)
Italy
Room: +39.06.9403.5248
Lab.: +39.06.9403.2286
Mob.: +39.06.9403.8025
Fax.: +39.06.9403.2597
- Re: Problem with drvAsynIPPortConfigure Dariush Hampai via Tech-talk
- Re: Problem with drvAsynIPPortConfigure Henrique F. Simoes via Tech-talk
- Problem with drvAsynIPPortConfigure Dariush Hampai via Tech-talk
<2025>
<2025>
