1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Problem with drvAsynIPPortConfigure
From: Dariush Hampai via Tech-talk <[email protected]>
To: "[email protected]" <[email protected]>, Mark Rivers <[email protected]>
Date: Thu, 18 Sep 2025 17:20:52 +0200
hi Community,
I'm writing an IOC for industrial motor driver:
I prepare the IOC, in particular:
1) in the configure/RELASE there is
SUPPORT=$(EPICS_BASE)/synApps_6_3/support
ASYN=$(SUPPORT)/asyn-R4-44-2
STREAM=$(SUPPORT)/StreamDevice-2-8-24
EPICS_BASE = /home/xlabsrv2/epics
2) in the mdrive_1IOC/src/Makefile there is
mdrive_1IOC_DBD += stream-base.dbd
mdrive_1IOC_DBD += drvAsynIPPort.dbd
mdrive_1IOC_DBD += asyn.dbd
mdrive_1IOC_LIBS += stream
mdrive_1IOC_LIBS += asyn
3) in the mdrive_1IOC/Db/Makefile there is
DB += mdrive_1IOC.proto
DB += mdrive_1IOC.db
DB += mdrive_1IOC.val
4) in the mdrive_1IOC/Db/mdrive_1IOC.val there is
file db/mdrive_1IOC.db {
    pattern { card, axis, ASYNPORT, MOT, EGU, homing, MRES, direct }
        { 1, 1 , "ip_x", "mdrive_x", mm, 1, 411, + }
5) in the st.cmd there is
epicsEnvSet ("STREAM_PROTOCOL_PATH", "${TOP}/db")
epicsEnvSet ("PORT_mdrive_x", "ip_x")
drvAsynIPPortConfigure($(PORT_mdrive_x), "100.100.0.23:503")
asynOctetSetInputEos($(PORT_mdrive_x),0,"\n\r")
asynOctetSetOutputEos($(PORT_mdrive_x),0,"\n\r")
asynSetTraceMask($(PORT_mdrive_x),-1,0x9);
asynSetTraceIOMask($(PORT_mdrive_x),-1,0x2)
These are the configurations. After make (all is ok), executing the st.cmd I receive the following error
[xlabsrv2@xlabsrv2 iocmdrive_1IOC]$ ./st.cmd
#!../../bin/linux-x86_64/mdrive_1IOC
< envPaths
epicsEnvSet("IOC","iocmdrive_1IOC")
epicsEnvSet("TOP","/home/xlabsrv2/epics/IOCs/mdrive_1IOC")
epicsEnvSet("SUPPORT","/home/xlabsrv2/epics/synApps_6_3/support")
epicsEnvSet("ASYN","/home/xlabsrv2/epics/synApps_6_3/support/asyn-R4-44-2")
epicsEnvSet("STREAM","/home/xlabsrv2/epics/synApps_6_3/support/StreamDevice-2-8-24")
epicsEnvSet("EPICS_BASE","/home/xlabsrv2/epics")
cd "/home/xlabsrv2/epics/IOCs/mdrive_1IOC"
epicsEnvSet ("STREAM_PROTOCOL_PATH", "/home/xlabsrv2/epics/IOCs/mdrive_1IOC/db")
#X Axis
drvAsynIPPortConfigure(ip_x, "100.100.0.23:503")
ERROR st.cmd line 36: Command drvAsynIPPortConfigure not found.
asynOctetSetInputEos(ip_x,0,"\n\r")
ERROR st.cmd line 37: Command asynOctetSetInputEos not found.
asynOctetSetOutputEos(ip_x,0,"\n\r")
ERROR st.cmd line 38: Command asynOctetSetOutputEos not found.
asynSetTraceMask(ip_x,-1,0x9);
ERROR st.cmd line 40: Command asynSetTraceMask not found.
asynSetTraceIOMask(ip_x,-1,0x2)
ERROR st.cmd line 41: Command asynSetTraceIOMask not found.
dbLoadDatabase "dbd/mdrive_1IOC.dbd"
mdrive_1IOC_registerRecordDeviceDriver pdbbase
## Load record instances
#dbLoadRecords("db/mdrive_1IOC.db","user=xlabsrv2")
dbLoadTemplate("db/mdrive_1IOC.val")
dbLoadTemplate: Too many values given, line 14.
cd "/home/xlabsrv2/epics/IOCs/mdrive_1IOC/iocBoot/iocmdrive_1IOC"
iocInit
Starting iocInit
## EPICS R7.0.8.2-DEV
## Rev. R7.0.8.1-142-g144f9756eac4e800f18d
## Rev. Date Git: 2025-02-05 10:16:16 -0600
2025/09/18 16:04:01.785392 _main_ Cannot find a bus named 'ip_x' for 'mdrive_x:model'
2025/09/18 16:04:01.785498 _main_ mdrive_x:model: Can't attach to bus ip_x 0
2025/09/18 16:04:01.785517 _main_ mdrive_x:model: Record initialization failed
## Start any sequence programs
#seq sncxxx,"user=xlabsrv2"
epics>
searching in previous threads I found missing the "drvAsynIPPort.dbd" in src/Makefile, but I already put it. Moreover I use "make clean all", and (to be sure) in this case I also remove db, dbd, and lib folders to restart with a clean make
where ma I wrong?
thank you in advance!!!
Dariush
p.s.: all other IOCs using drvAsynIPPortConfigure working properly...
Dr. Dariush Hampai, PhD
INFN - LNF
X-Lab Frascati
Via E. Fermi, 54 (ex 40)
I-00044 Frascati (RM)
Italy
Mail Address:
XLab-Frascati
LNF-INFN
Casella Postale 13
Frascati (RM)
Italy
Room:	+39.06.9403.5248
Lab.:	+39.06.9403.2286
Mob.:	+39.06.9403.8025
Fax.:	+39.06.9403.2597
RE: Problem with drvAsynIPPortConfigure Mark Rivers via Tech-talk
Re: Problem with drvAsynIPPortConfigure Ralph Lange via Tech-talk
Prev: Re: Help with bumpless IOC reboot, record linking and initialization concepts Johnson, Andrew N. via Tech-talk
Next: RE: Problem with drvAsynIPPortConfigure Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Prev: Re: Help with bumpless IOC reboot, record linking and initialization concepts Marco Filho via Tech-talk
