1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: The motor module is unable to control the PM600 motor.
From: LONG FENG via Tech-talk <tech-talk at aps.anl.gov>
To: tech-talk at aps.anl.gov
Date: Fri, 9 Jan 2026 15:32:22 +0800
Hi all,
During the configuration of the motor module, everything seems normal: communication is working, and startup proceeds correctly. However, it is still unable to control the motor. Below is the output information from the startup process:
#!../../bin/linux-x86_64/motor
< envPaths
epicsEnvSet("IOC","iocmotor")
epicsEnvSet("TOP","/home/training/ConditionMonitoring")
epicsEnvSet("EPICS_BASE","/ics/tools/base-7.0.6")
epicsEnvSet("PYDEVICE","/ics/tools/PyDevice-R1.1.1")
epicsEnvSet("PVXS","/ics/tools/pvxs")
epicsEnvSet("ETHER_IP","/ics/tools/ether_ip")
epicsEnvSet("SNCSEQ","/ics/tools/seq-2.2.9")
epicsEnvSet("AUTOSAVE","/ics/tools/autosave-R5-10-2")
epicsEnvSet("ASYN","/ics/tools/asyn4-38")
epicsEnvSet("STREAM","/ics/tools/StreamDevice-master")
epicsEnvSet("MOTOR","/ics/tools/motor")
epicsEnvSet("BUSY","/ics/tools/busy-1-6-1")
epicsEnvSet("MODBUS","/ics/tools/modbus")
epicsEnvSet("CALC","/ics/tools/calc")
epicsEnvSet("STD","/ics/tools/std")
cd "/home/training/ConditionMonitoring"
dbLoadDatabase "dbd/motor.dbd"
motor_registerRecordDeviceDriver pdbbase
drvAsynIPPortConfigure("mclennanMotor", "192.168.1.15:4196")
asynSetTraceMask("mclennanMotor", 0, 2)
asynSetTraceIOMask("mclennanMotor", 0, 2)
# --------- initialize PM304 driver (must be compiled into IOC) ----------
# PM304Setup(num_cards, scan_rate)
#   num_cards: maximum controllers, scan_rate: polling rate (1..60) in 1/60s units
PM304Setup(1, 5)
# PM304Config(cardIndex, portName, n_axes)
# cardIndex: 0-based index of controller
# portName: asyn port name above
# n_axes: number of axes on that controller (set to actual count)
PM304Config(0, "mclennanMotor", 1)
## Load record instances
#dbLoadRecords("db/motor.db","user=flon")
dbLoadRecords("db/mclennanMotor.db", "P=Mclennan, M=SM9749, PORT=mclennanMotor, ADDR=1")
cd "/home/training/ConditionMonitoring/iocBoot/iocmotor"
iocInit
Starting iocInit
## EPICS R7.0.6
## Rev. 2021-09-28T15:27-0400
2026/01/09 02:19:36.711 asynOctetSyncIO flush
2026/01/09 02:19:36.713 asynOctetSyncIO wrote:
1OA
2026/01/09 02:19:38.729 asynOctetSyncIO wrote:
1ST
2026/01/09 02:19:40.743 asynOctetSyncIO wrote:
1ID
2026/01/09 02:19:42.753 asynOctetSyncIO wrote:
1ID
2026/01/09 02:19:44.769 asynOctetSyncIO wrote:
1OS
2026/01/09 02:19:46.780 asynOctetSyncIO wrote:
1OA
## Start any sequence programs
#seq sncxxx,"user=flon"
epics>
 When I set $(P)$(M).VAL to 100, the output is:
epics> 2026/01/09 02:21:31.520 asynOctetSyncIO wrote:
1SV1
2026/01/09 02:21:33.536 asynOctetSyncIO wrote:
1SA2
2026/01/09 02:21:35.550 asynOctetSyncIO wrote:
1SD2
2026/01/09 02:21:37.562 asynOctetSyncIO wrote:
1MA100
2026/01/09 02:21:39.578 asynOctetSyncIO wrote:
1OS
2026/01/09 02:21:41.588 asynOctetSyncIO wrote:
1OA
2026/01/09 02:21:43.603 asynOctetSyncIO wrote:
1SV1
2026/01/09 02:21:45.616 asynOctetSyncIO wrote:
1SA2
2026/01/09 02:21:47.628 asynOctetSyncIO wrote:
1SD2
2026/01/09 02:21:49.640 asynOctetSyncIO wrote:
1MA100
2026/01/09 02:21:51.669 asynOctetSyncIO wrote:
1OS
2026/01/09 02:21:53.706 asynOctetSyncIO wrote:
1OA
2026/01/09 02:21:55.720 asynOctetSyncIO wrote:
1SV1
2026/01/09 02:21:57.733 asynOctetSyncIO wrote:
1SA2
2026/01/09 02:21:59.745 asynOctetSyncIO wrote:
1SD2
2026/01/09 02:22:01.759 asynOctetSyncIO wrote:
1MA100
No errors are reported, but the motor still does not move. Are there any other aspects I should check?
Here is my .db file; perhaps it can help identify the problem.
record(motor, "$(P)$(M)")
    field(DESC, "PM600")
    field(DTYP, "Mclennan PM304")
#   field(OUT, "@asyn($(PORT) $(ADDR))")
    field(OUT, "#C0 S0 @")
    field(EGU, "mm")
    field(MRES, "1")
    field(VELO, "1")
    field(ACCL, ".5")
    field(VBAS, ".1")
    field(DHLM, "100")
    field(DLLM, "0")
    field(TWV,  "1")
    field(PREC, "1")
Feng
Re: The motor module is unable to control the PM600 motor. Mark Rivers via Tech-talk
Prev: Re: Re: Re: The problem of converting floating-point numbers to 4-byte format (in CDAB order) under StreamDevice 高振华 via Tech-talk
Next: Re: problems with SNL - sevr=minor ca_array_get_callback [...]: Virtual circuit disconnect Dariush Hampai via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: RE: problems with SNL - sevr=minor ca_array_get_callback [...]: Virtual circuit disconnect Žiga Oven via Tech-talk
Next: Re: The motor module is unable to control the PM600 motor. Mark Rivers via Tech-talk
