1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: MAXnet Alarm State Under High Motor Command Load
From: Jiajun Tian via Tech-talk <tech-talk at aps.anl.gov>
To: "Peterson, Kevin M." <kmpeters at anl.gov>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Mon, 9 Mar 2026 15:43:41 +0000
Hi Kevin,
Thanks for your help. Following the error message, we determined that the issue was related to the driver. We were using a newer model ACS driver with a relatively old motor, which caused the incompatibility. After switching to the appropriate driver, the problem was resolved.
Best,
Jiajun
Jiajun Tian, Ph.D.
Postdoctoral Researcher
NSF’s ChemMatCARS, Pritzker School of Molecular Engineering
University of Chicago
9700 S Cass Ave Bldg 434D
Lemont, IL-60439
United States
Sent: Wednesday, February 11, 2026 4:04 PM
To: Jiajun Tian <jiajtian at uchicago.edu>; tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
If you uncomment the USR_CXXFLAGS line from omsAsynApp/srcMakfile:
https://urldefense.com/v3/__https://github.com/epics-motor/motorOmsAsyn/blob/c0ae4c740d699e64f264ce6f53f23a492abf19fa/omsAsynApp/src/Makefile*L8__;Iw!!BpyFHLRN4TMTrA!-omSqwr9ZTVcKOxtXsinkdQPcCcC6h-UC2glC45EocFBoWFuWBrMJaZYjzkrj5AMhDLh8xRDh5Bc6XqgXl_wrA$
and uncomment the motorOMSBASEdebug variable in omsAsynMAXnetSupport.dbd:
https://urldefense.com/v3/__https://github.com/epics-motor/motorOmsAsyn/blob/c0ae4c740d699e64f264ce6f53f23a492abf19fa/omsAsynApp/src/omsAsynMAXnetSupport.dbd*L2__;Iw!!BpyFHLRN4TMTrA!-omSqwr9ZTVcKOxtXsinkdQPcCcC6h-UC2glC45EocFBoWFuWBrMJaZYjzkrj5AMhDLh8xRDh5Bc6Xq91hlH6Q$
and rebuild motorOmsAsyn and the IOC, you should then be able to set the variable on the IOC's shell:
var("motorOMSBASEdebug", 4)
which should result in a "setting Problem flag" message being printed.
Kevin
Re: MAXnet Alarm State Under High Motor Command Load Mrinal Bera via Tech-talk
MAXnet Alarm State Under High Motor Command Load Jiajun Tian via Tech-talk
Re: MAXnet Alarm State Under High Motor Command Load Peterson, Kevin M. via Tech-talk
Re: MAXnet Alarm State Under High Motor Command Load Jiajun Tian via Tech-talk
Prev: Re: Help in debugging ACF connection issue Érico Nogueira Rolim via Tech-talk
Next: RE: Help in debugging ACF connection issue Stephen Dann - STFC UKRI via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: Re: MAXnet Alarm State Under High Motor Command Load Peterson, Kevin M. via Tech-talk
Next: Re: MAXnet Alarm State Under High Motor Command Load Mrinal Bera via Tech-talk
ANJ, 24 Mar 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
