1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: question about pvmonitor behavior
From: "Railton, Irie \(STFC,RAL,CLF\) via Tech-talk" <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Tue, 17 Mar 2026 14:41:01 +0000
Hi Alfio,
The pvmonitor/camonitor tools only updates (without a restart) when a PV is processed and with this setup the myaipv record does not process.
So to make the change show in the monitor you must make either the myaipv record process or restart the monitor.
To make the record process you could either add a FLNK field to the myaopv record pointing to the myaipv like so:
record(ao, "myaopv") {
    field(PINI, "YES")
    field(VAL, 30)
    field(OUT, "myaipv")
    field(FLNK, "myaipv")
Or more succinctly, you could add a PP to the OUT field like so:
    field(PINI, "YES")
    field(VAL, 30)
    field(OUT, "myaipv PP")
You could also observe the PV changing in the monitor without these modifications to the database by forcing the myaipv record to process with a write to the PROC field like so:
pvput myaipv.PROC 1
Kind regards,
Irie Railton
Software Engineer
Software Controls Group
CLF Engineering Division
Prev: Re: question about pvmonitor behavior Alfio Rizzo via Tech-talk
Next: Re: question about pvmonitor behavior Érico Nogueira Rolim via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: Re: question about pvmonitor behavior Érico Nogueira Rolim via Tech-talk
Next: [ANN] e3 - major architectural update Anders Lindh Olsson via Tech-talk
