Hello Nick,
On 6/8/26 8:35 AM, Marks, Nicholas via
Tech-talk wrote:
Hello,
I was curious if there has been any discussion in the community
about implementing a Channel Access provider for PVXS? I think
most would agree the PVXS API is much easier to work with than
the pvAccessCPP API, however one thing pvAccessCPP has over PVXS
is it also provides a CA
provider(epics::pvAccess::ca::CAClientFactory::start();
pvac::ClientProvider provider("ca");).
I was not enthused about supporting the (imo.) hacky code behind
CA ClientProvider. Wrapping libca adds the problem of API
impedance mismatch to the differences between the two protocols.
I do not see a similar wrapper appearing in PVXS. I would not
rule out including a new CA implementation, with a similar API,
but this is not at all a priority for me.
Any
new client applications will likely need to support both CA and
PVA (except maybe for some very new sites which are trying PVA
only) so it is especially useful to have a single API for the
EPICS communication layer of such an application. The way I see
it, a C++ EPICS client which is to support both CA and PVA will
need to use PVXS for PVA and the C API for Channel Access or
alternatively stick with pvAccessCPP. This isn't the end of the
world, but it sure would be nice to use PVXS for both protocols.
I'm interested to hear others' thoughts on this.
To my mind, dual protocol servers are the way to go. I think the
server side is better equipped to handle the differences between
the two protocols. Including QSRV2 in all IOCs provides a ~95%
solution.
If "transparent" support for PVA/CA is critical for your client
application, and "pvac::ClientProvider" + CAProvider works for
you, then great. "pvac::" was my last attempt to wrap a
not-horrible API around pvAccessCPP. Like much of the original
pvDataCPP stack, it is in deep maintenance mode at this point.
Still, the EPICS community has a history of keeping such code
~viable for a very long time. I doubt that obsolescence will
force a migration on you anytime soon.
