1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: EPICS support for Fastech motors
From: Torsten Bögershausen via Tech-talk <tech-talk at aps.anl.gov>
To: Rea Domitrović <rea.domitrovic at irb.hr>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Wed, 10 Jun 2026 13:49:41 +0200
Hej Rea,
I haven't worked with them, no.
If you have Ethernet (not to be confused with EtherCAT),
I read the manual as if they use UDP for communication,
and knowing that you can write a simple model 3 driver, I think.
(Other suggestions are welcome of course)
/Torsten
On 2026-06-10 12:52, Rea Domitrović via Tech-talk wrote:
Hi all,
I'm working with some Fastech Ezi-Servo II Plus-E motors, and I was wondering if someone had already worked with them and/or made an EPICS driver or Motor submodule? This particular line of motors and drives uses an Ethernet interface. Kind regards,
Rea Domitrović
Institut Ruđer Bošković
Zagreb, Croatia
Re: EPICS support for Fastech motors Rea Domitrović via Tech-talk
Prev: EPICS support for Fastech motors Rea Domitrović via Tech-talk
Next: Re: Strange problem linking a library on windows-x64 Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Next: Re: EPICS support for Fastech motors Rea Domitrović via Tech-talk
ANJ, 17 Jun 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
