Hi Torsten,
thanks for pointing me in the right direction. I'm looking at the manual and the source for other submodules now (motorSmarAct and motorAcs); I see that driver developers prefer to use octet-based communication rather than use the manufacturer-provided libraries. Is there a reason why that is the case, or is it simply that octet-based communicaton is more universal?
Further, the Fastech controller allows both octet-based communication and library-based communication, but octet-based communication requires the master to send a one-byte "sync number" which serves as an idempotence token. I assume it would be necessary to implement that myself; could I be using some sort of global variable, and how do I make sure that I never land on the same number twice in a row? Kind regards,
Rea From: Torsten Bögershausen <tboegi at edom.se>
Sent: Wednesday, June 10, 2026 1:49:41 PM To: Rea Domitrović; tech-talk at aps.anl.gov Subject: Re: EPICS support for Fastech motors Hej Rea,
I haven't worked with them, no. If you have Ethernet (not to be confused with EtherCAT), I read the manual as if they use UDP for communication, and knowing that you can write a simple model 3 driver, I think. (Other suggestions are welcome of course) /Torsten On 2026-06-10 12:52, Rea Domitrović via Tech-talk wrote: > Hi all, > > > I'm working with some Fastech Ezi-Servo II Plus-E motors, and I was > wondering if someone had already worked with them and/or made an EPICS > driver or Motor submodule? This particular line of motors and > drives uses an Ethernet interface. Kind regards, > > > Rea Domitrović > > Institut Ruđer Bošković > > Zagreb, Croatia > Oprez: Ova poruka stigla je od vanjskog pošiljatelja. Prije otvaranja poveznica ili privitaka provjerite pošiljatelja. Caution:This email originated from an external sender. Please verify the sender before opening links or attachments.
| ANJ, 17 Jun 2026 |
Home
News
About
Talk
Base
Modules
Extensions
