1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026
Subject: Problem building on windows-x64
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: EPICS Tech Talk <tech-talk at aps.anl.gov>
Date: Wed, 10 Jun 2026 14:37:51 +0000
Folks,
I am having intermittent problems building on windows-x64.  I get errors like this:
link -nologo -subsystem:windows -dll -LTCG -incremental:no -opt:ref -release  -MACHINE:X64           -out:quadEM.dll -implib:quadEM.lib     drvQuadEM.obj drvSoftQuadEM.obj        J:/epics/devel/areaDetector-3-14/ADCore/lib/windows-x64/ADBase.lib  J:/epics/devel/asyn-4-46/lib/windows-x64/asyn.lib  J:/epics/devel/areaDetector-3-14/ADCore/lib/windows-x64/ntndArrayConverter.lib  H:/epics-devel/base-7.0.10/lib/windows-x64/nt.lib  H:/epics-devel/base-7.0.10/lib/windows-x64/pvDatabase.lib  H:/epics-devel/base-7.0.10/lib/windows-x64/pvAccess.lib  H:/epics-devel/base-7.0.10/lib/windows-x64/pvData.lib  J:/epics/devel/pvxs/lib/windows-x64/pvxsIoc.lib  J:/epics/devel/pvxs/lib/windows-x64/pvxs.lib  J:/epics/devel/areaDetector-3-14/ADCore/lib/windows-x64/ntndArrayConverterPvxs.lib  J:/epics/devel/areaDetector-3-14/ADSupport/lib/windows-x64/netCDF.lib  J:/epics/devel/areaDetector-3-14/ADSupport/lib/windows-x64/nanohttp_stream.lib  J:/epics/devel/areaDetector-3-14/ADSupport/lib/windows-x64/Magick++.lib  J:/epics/devel/areaDetector-3-14/ADSupport/lib/windows-x64/coders.lib  J:/epics/devel/areaDetector-3-14/ADSupport/lib/windows-x64/Magick.lib  J:/epics/devel/areaDetector-3-14/ADSupport/lib/windows-x64/jbig.lib  J:/epics/devel/areaDetector-3-14/ADSupport/lib/windows-x64/jp2.lib  J:/epics/devel/areaDetector-3-14/ADSupport/lib/windows-x64/bzlib.lib  J:/epics/devel/areaDetector-3-14/ADSupport/lib/windows-x64/png.lib  J:/epics/devel/areaDetector-3-14/ADSupport/lib/windows-x64/webp.lib  J:/epics/devel/areaDetector-3-14/ADSupport/lib/windows-x64/lcms.lib  J:/epics/devel/areaDetector-3-14/ADSupport/lib/windows-x64/ttf.lib  J:/epics/devel/areaDetector-3-14/ADSupport/lib/windows-x64/wmf.lib  J:/epics/devel/areaDetector-3-14/ADSupport/lib/windows-x64/filters.lib  J:/epics/devel/areaDetector-3-14/ADSupport/lib/windows-x64/tiff.lib  J:/epics/devel/areaDetector-3-14/ADSupport/lib/windows-x64/xml2.lib  J:/epics/devel/areaDetector-3-14/ADSupport/lib/windows-x64/NeXus.lib  J:/epics/devel/areaDetector-3-14/ADSupport/lib/windows-x64/hdf5_hl.lib  J:/epics/devel/areaDetector-3-14/ADSupport/lib/windows-x64/hdf5.lib  J:/epics/devel/areaDetector-3-14/ADSupport/lib/windows-x64/bitshuffle.lib  J:/epics/devel/areaDetector-3-14/ADSupport/lib/windows-x64/lz4hdf5.lib  J:/epics/devel/areaDetector-3-14/ADSupport/lib/windows-x64/blosc.lib  J:/epics/devel/areaDetector-3-14/ADSupport/lib/windows-x64/szip.lib  J:/epics/devel/areaDetector-3-14/ADSupport/lib/windows-x64/zlib.lib  J:/epics/devel/areaDetector-3-14/ADSupport/lib/windows-x64/jpeg.lib  H:/epics-devel/base-7.0.10/lib/windows-x64/dbRecStd.lib  H:/epics-devel/base-7.0.10/lib/windows-x64/dbCore.lib  H:/epics-devel/base-7.0.10/lib/windows-x64/ca.lib  H:/epics-devel/base-7.0.10/lib/windows-x64/Com.lib  J:/epics/devel/pvxs/bundle/usr/windows-x64/lib/event_core.lib gdi32.lib oleaut32.lib bcrypt.lib iphlpapi.lib netapi32.lib ws2_32.lib
   Creating library quadEM.lib and object quadEM.exp
LINK : fatal error LNK1104: cannot open file 'quadEM.exp'
make[1]: *** [H:/epics-devel/base-7.0.10/configure/RULES_BUILD:317: quadEM.dll] Error 1104
make[1]: Leaving directory 'J:/epics/devel/quadEM/quadEMApp/quadEMSrc/O.windows-x64'
make: *** [H:/epics-devel/base-7.0.10/configure/RULES_ARCHS:58: install.windows-x64] Error 2
Note that is says it could not open quadEM.exp.  However, it actually did create that file as seen here:
J:\epics\devel\quadEM\quadEMApp\quadEMSrc>dir O.windows-x64
 Volume in drive J is people_rw
 Volume Serial Number is 5005-CD09
 Directory of J:\epics\devel\quadEM\quadEMApp\quadEMSrc\O.windows-x64
06/10/2026  09:30 AM    <DIR>          .
06/10/2026  09:29 AM    <DIR>          ..
06/10/2026  09:29 AM               202 Makefile
06/10/2026  09:29 AM             4,135 drvSoftQuadEM.d
06/10/2026  09:29 AM             3,852 drvQuadEM.d
06/10/2026  09:29 AM         1,705,689 drvQuadEM.obj
06/10/2026  09:29 AM         1,623,888 drvSoftQuadEM.obj
06/10/2026  09:30 AM             7,059 quadEM.exp
06/10/2026  09:30 AM            12,070 quadEM.lib
               7 File(s)      3,356,895 bytes
               2 Dir(s)  9,567,843,336,192 bytes free
The problem is intermittent, if I try to build several times eventually it usually works.
My EPICS files reside on a Linux file server which is mounted with SMB from the Windows workstation.  This has worked fine for 20+ years.  But recently I started having these problems.  I have not changed the Visual Studio environment recently, and it was previously working.  The Linux OS (RHEL 9.7) and the Windows 11 OS are relatively new.  I am suspecting a problem with file locking or file caching on the SMB files.  Has anyone else run into this problem?
Prev: Re: Strange problem linking a library on windows-x64 Mark Rivers via Tech-talk
Next: Re: AreaDetector Collaboration Meeting - June 11th Érico Nogueira Rolim via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026
Prev: Re: EPICS support for Fastech motors Rea Domitrović via Tech-talk
Next: Auto-Scaling in Phoebus Display Builder Vishnu Patel via Tech-talk
ANJ, 29 Jun 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
