Thanks for this.
I'm taking a look. I note that the beagleboneblack BSP now fails to build because of several instances of "pointer targets in passing argument (n) of (whatever) differ in signedness [-Werror=pointer-sign]"
Hi Mike,
Right, I’ve tried to make my current RTEMS7 development with BeagleBon Black available in a public repository:
git clone --recurse-submodules https://github.com/hjunkes/RTEMS_BBB.git
In it, you’ll find RTEMS installation scripts, as well as my modifications to the kernel and rtems-libbsd.
EPICS is also included, with epics-base and support modules such as pvxs in epics-support.
There is also an FHI folder containing an example IOC (beaglePyroIOC).
In epics-base/modules/libcom/RTEMS/posix/rtems_init.c ist der NTP host hard coded.
And here are the DHCP settings for the BBB:
"options": [
"name": "user-class",
"num": 77,
"value": "/Volumes/Epics/BEAGLEBONE/beaglePyroIOC/iocBoot/iocbeaglePyroIOC/st.cmd",
"vendor_class": "DHCP"
"name": "ntp-servers",
"num": 42,
"value": "141.14.138.238",
"name": "tftp-server-name",
"num": 66,
"value": "141.14.131.192:/Volumes/Epics",
"name": "rtems-cmdline",
"num": 129,
"name": "bootfile-name",
"num": 67,
"value": "/Volumes/Epics/BEAGLEBONE/beaglePyroIOC/bin/RTEMS-beagleboneblack/beaglePyroIOC",
"name": "host-name",
"num": 12,
"value": "beaglebone",
"name": "dhcp-lease-time",
"num": 51,
"use_option": false,
"value": "43200",
HTH, Heinz
Fritz-Haber-Institut | Phone: (+49 30) 8413-4270
Heinz Junkes | VC: https://zoom.fhi.berlin/junkes
Faradayweg 4-6 | Visitors: Hittorfstrasse 29 (Bld S (Slough House) )
D - 14195 Berlin
“Sorry I’m a bit late, had a terrible time…
All sort of things cropping up at the last moment. Uh, how are we for time?”
—Zarquon's address to Milliways
> On 16. Jun 2026, at 17:59, Mike Westfall <mwdlanm at gmail.com> wrote:
> Hi Heinz.
> Thanks for your response.
> I did notice that after a while, the DHCP request times out and the init continues with trying to nfs mount some default paths hardcoded into EPICS. These of course fail too.
> This is not urgent.
> I'm just experimenting for personal learning purposes.
> ---- Waiting for DHCP ...
> info: version 6.2.1 starting
> err: no valid interfaces found
> warning: no interfaces have a carrier
> ---- DHCP timed out!
> -------------- IFCONFIG -----------------
> lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 16384
> options=680003<RXCSUM,TXCSUM,LINKSTATE,RXCSUM_IPV6,TXCSUM_IPV6>
> inet 127.0.0.1 netmask 0xffffff00
> inet6 ::1 prefixlen 128
> inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
> nd6 options=21<PERFORMNUD,AUTO_LINKLOCAL>
> groups: lo
> -------------- NETSTAT ------------------
> Routing tables
> Internet:
> Destination Gateway Flags Netif Expire
> 127.0.0.1 link#1 UH lo0
> Internet6:
> ::1 link#1 UH lo0
> fe80::%lo0/64 link#1 U lo0
> fe80::1%lo0 link#1 UHS lo0
> ***** Until now no NTP support in RTEMS 5 with rtems-libbsd *****
> ***** Ask ntp server once... *****
> ***** No NTP server ...
> ***** Setting up file system *****
> ***** Initializing NFS *****
> nfsMount("[email protected]", "/epics", "/epics")
> Mount [email protected]:/epics on /epics
> nfs: mount: nfs -> [email protected]:/epics
> nfs: mount: user/group name in path not supported
> mount failed: Invalid argument
> check for time registered , C++ initialization ...
> ***** Preparing EPICS application *****
> Can't set initial directory(/epics/myExample/iocBoot/iocmyExample/): No such file or directory
> Can't set initial directory(%s): %s
> *** FATAL ***
> fatal source: 11 (RTEMS_FATAL_SOURCE_PANIC)
> fatal code: 2153112536 (0x8055e3d8)
> RTEMS version: 6.0.0.not-released
> RTEMS tools: 13.3.0 20240521 (RTEMS 6, RSB no-repo, Newlib 1b3dcfd)
> executing thread ID: 0x0b010001
> executing thread name: _main_
> U-Boot SPL 2016.11-rc3-00002-g73df7f7 (Nov 04 2016 - 15:20:36)
> Trying to boot from MMC2
> On Tue, Jun 16, 2026 at 10:28 AM Heinz Junkes <junkes at fhi-berlin.mpg.de> wrote:
> Hallo Mike,
> I have been using BeagleBone Black with RTEMS-LibBSD 6.1 in production so far
> and BeagleBone Black with rtems-libbsd and RTEMS 7, due to be released shortly.
> However, I’ve made a lot of changes over the last six months, and these haven’t been incorporated into EPICS-Base yet.
> Over the next few days, I’ll try to document my changes to the RTEMS kernel as well and make them available for download.
> Is it urgent? If so, I’d be happy to send you a version in the meantime.
> Heinz
> D - 14195 Berlin
> > On 16. Jun 2026, at 15:24, Mike Westfall via Tech-talk <tech-talk at aps.anl.gov> wrote:
> > Looking for advice from anyone who has experience running an IOC under RTEMS on a Beaglebone Black.
> > It looks like I can load the IOC image and the it starts executing , but it seems like it stops stops when it can't find the ethernet interface.
> > Here is the console output of the boot up:
> > U-Boot 2016.11-rc3-00002-g73df7f7 (Nov 04 2016 - 15:20:36 -0500), Build: jenkin9
> > CPU : AM335X-GP rev 2.1
> > I2C: ready
> > DRAM: 512 MiB
> > Reset Source: Global external warm reset has occurred.
> > Reset Source: Power-on reset has occurred.
> > MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1
> > Using default environment
> > Board: BeagleBone Black
> > <ethaddr> not set. Validating first E-fuse MAC
> > Net: eth0: MII MODE
> > cpsw
> > Press SPACE to abort autoboot in 2 seconds
> > board_name=[A335BNLT] ...
> > board_rev=[00C0] ...
> > switch to partitions #0, OK
> > mmc0 is current device
> > SD/MMC found on device 0
> > ** Bad device 0:2 0x82000000 **
> > Scanning mmc 0:1...
> > reading /am335x-boneblack.dtb
> > 99116 bytes read in 15 ms (6.3 MiB/s)
> > gpio: pin 56 (gpio 56) value is 0
> > gpio: pin 55 (gpio 55) value is 0
> > gpio: pin 54 (gpio 54) value is 0
> > gpio: pin 53 (gpio 53) value is 1
> > gpio: pin 54 (gpio 54) value is 1
> > Checking for: /uEnv.txt ...
> > reading uEnv.txt
> > 173 bytes read in 5 ms (33.2 KiB/s)
> > gpio: pin 55 (gpio 55) value is 1
> > Loaded environment from /uEnv.txt
> > Importing environment from mmc ...
> > Checking if uenvcmd is set ...
> > gpio: pin 56 (gpio 56) value is 1
> > Running uenvcmd ...
> > link up on port 0, speed 100, full duplex
> > BOOTP broadcast 1
> > DHCP client bound to address 192.168.0.186 (6 ms)
> > Using cpsw device
> > TFTP from server 192.168.0.143; our IP address is 192.168.0.186
> > Filename 'rtems-app.img'.
> > Load address: 0x80800000
> > Loading: #################################################################
> > 2.5 MiB/s
> > done
> > Bytes transferred = 2819094 (2b0416 hex)
> > BOOTP broadcast 1
> > DHCP client bound to address 192.168.0.186 (7 ms)
> > Using cpsw device
> > Filename 'am335x-boneblack.dtb'.
> > Load address: 0x88000000
> > Loading: #######
> > 2 MiB/s
> > done
> > Bytes transferred = 99116 (1832c hex)
> > ## Booting kernel from Legacy Image at 80800000 ...
> > Image Name: sampleIOC
> > Created: 2026-06-15 16:44:43 UTC
> > Image Type: ARM Linux Kernel Image (gzip compressed)
> > Data Size: 2819030 Bytes = 2.7 MiB
> > Load Address: 80000000
> > Entry Point: 80000000
> > Verifying Checksum ... OK
> > ## Flattened Device Tree blob at 88000000
> > Booting using the fdt blob at 0x88000000
> > Uncompressing Kernel Image ... OK
> > Loading Device Tree to 8ffe4000, end 8ffff32b ... OK
> > Starting kernel ...
> > RTEMS Beagleboard: am335x-based
> > ARM Debug: 0x4b141000
> > WARNING: OS Clock time was read before being set.
> > Using 1990-01-02 00:00:00.000000 UTC
> > initConsole --- Info ---
> > stdin: fileno: 0, ttyname: /dev/console
> > stdout: fileno: 1, ttyname: /dev/console
> > stderr: fileno: 2, ttyname: /dev/console
> > time set to : 04/14/14 07:30:06.000002041 UTC
> > Startup.
> > epicsThreadSetPriority called by non epics thread
> > ***** RTEMS Version: rtems-6.0.0 (ARM/ARMv4/beagleboneblack) *****
> > ***** Initializing network (libbsd, dhcpcd) *****
> > nexus0: <RTEMS Nexus device>
> > ofwbus0: <Open Firmware Device Tree> on nexus0
> > ***** ifconfig lo0 *****
> > info: lo0: link state changed to UP
> > ***** add dhcpcd hook *****
> > ***** Start default network dhcpcd *****
> > --Info (hpj)-- bsd task prio IRQS: 96 -----
> > --Info (hpj)-- bsd task prio TIME: 98 -----
- Re: EPICS, RTEMS, Beaglebone Black Heinz Junkes via Tech-talk
- EPICS, RTEMS, Beaglebone Black Mike Westfall via Tech-talk
- Re: EPICS, RTEMS, Beaglebone Black Mike Westfall via Tech-talk
Re: EPICS support for Fastech motors Mark Rivers via Tech-talk
Re: IOCs - What are the built-in device types? Johnson, Andrew N. via Tech-talk
2025
<2026>
2025
<2026>
