1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: Search issue for pva:// PVs in Archiver Appliance
From: Sky Brewer via Tech-talk <tech-talk at aps.anl.gov>
To: 吕慧慧 <lvhh at sari.ac.cn>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Mon, 22 Jun 2026 07:07:37 +0000
Hi Huihui,
Once the PV is added you don’t need the prefix to search of the PV. You also don’t need the prefix at all if you set the default protocol in the archappl.properties to PVA.
Hope this helps
Sky
Sent from Outlook for Mac
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of 吕慧慧 via Tech-talk <tech-talk at aps.anl.gov>
Date: Monday, 22 June 2026 at 04:14
To: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Subject: Search issue for pva:// PVs in Archiver Appliance
Hi everyone,
I’m configuring Archiver Appliance to use only PVA. PVs are added as pva://pv_name.
Problem: Searching by full PV name fails to return these entries, even with exact matching.
Does anyone know how to fix the PV search indexing for PVA-prefixed PVs?
Huihui
Search issue for pva:// PVs in Archiver Appliance 吕慧慧 via Tech-talk
Prev: Search issue for pva:// PVs in Archiver Appliance 吕慧慧 via Tech-talk
Next: Re: Problems with Dante (XGLab) Driver Dariush Hampai via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Next: ASYN parameter value vs VAL field relationship André Favoto via Tech-talk
ANJ, 22 Jun 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
