1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: ASYN parameter value vs VAL field relationship
From: André Favoto via Tech-talk <tech-talk at aps.anl.gov>
To: Tech Talk <tech-talk at aps.anl.gov>
Date: Mon, 22 Jun 2026 11:28:04 +0000
Hi folks,
I am trying to control the upper limit for a given PV via asyn (same as DRVH does, but since the value is dynamic, I'd rather handle it in the driver instead of DB links).
I have the following record:
record(ao, "$(P)$(R)$(PUMP)MaxPressure") {
    field(DESC, "set max pressure for process")
    field(DTYP, "asynFloat64")
    field(EGU,  "bar")
    field(PREC, "2")
    field(OUT,  "@asyn($(PORT),$(ADDR),$(TIMEOUT))PROC_MAX_PRESSURE")
    info(asyn:READBACK, "1")
Re: ASYN parameter value vs VAL field relationship André Favoto via Tech-talk
Prev: Re: Problems with Dante (XGLab) Driver Dariush Hampai via Tech-talk
Next: Re: ASYN parameter value vs VAL field relationship André Favoto via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: Re: Search issue for pva:// PVs in Archiver Appliance Sky Brewer via Tech-talk
ANJ, 22 Jun 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
