1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026
Subject: Archiver Appliance cannot archive structured PV data
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Wed, 1 Jul 2026 10:38:42 +0800 (GMT+08:00)
Hi all,
I have implemented a structured PVA data in an EPICS V7 IOC. The db is as follows:
record(longin, "DEV1:RED:SHOT_ID_TEST") {
    field(DTYP, "PSC Reg")
    field(INP , "@$(NAME) 526 2")
    field(SCAN, "I/O Intr")
    field(TSE , "-2")
    info(Q:group, {
        "DEV1:RED:WAVE_TEST_PVA": {
            "COUNT": {
                +channel:"VAL"
record(waveform, "DEV1:RED:WAVE_TEST_C1") {
    field(DTYP, "PSC Block I16 In")
    field(INP , "@$(NAME) 8193")
    field(FTVL, "DOUBLE")
    field(NELM, "20000000")
    info(Q:group,{
            "VALUE": {
                +channel:"VAL"
When I try to archive this PV using the pva://pvname prefix in Archiver Appliance, the archiver throws error messages  and cannot establish persistent archiving.
2026-06-30 15:48:19,766 ERROR [JCA Command Thread 9] pv.EPICS_V4_PV (EPICS_V4_PV.java:241) - Cannot determine the timestamp bitset for PV DEVI:RED:WAVE_TEST_PVA. This means we may not save any data at all for this PV
2026-06-30 15:48:19,767 ERROR [JCA Command Thread 9] pv.EPICS_V4_PV (EPICS_V4_PV.java:442) - exception when reading pv
java.lang.reflect.InvocationTargetException: null
at jdk.internal.reflect.DirectConstructorHandleAccessor.newInstance(DirectConstructorHandleAccessor.java:72) ~[?:?]
at java.lang.reflect.Constructor.newInstanceWithCaller(Constructor.java:502) ~[?:?]
at java.lang.reflect.Constructor.newInstance(Constructor.java:486) ~[?:?]
at org.epics.archiverappliance.engine.pv.EPICS_V4_PV.fromStructure(EPICS_V4_PV.java:278) ~[classes/:?]
at org.epics.archiverappliance.engine.pv.EPICS_V4_PV.subscribe(EPICS_V4_PV.java:438) ~[classes/:?]
at org.epics.archiverappliance.engine.pv.EPICS_V4_PV.handleConnected(EPICS_V4_PV.java:388) ~[classes/:?]
at org.epics.archiverappliance.engine.pv.JCACommandThread.run(JCACommandThread.java:194) [classes/:?]
Caused by: java.lang.NullPointerException: Cannot invoke "org.epics.vtype.PVStructure.getString()" because "timestampPVStructure" is null
at org.epics.archiverappliance.common.TimeUtils.convertFromPVTimestamp(TimeUtils.java:531) ~[classes/:?]
at edu.stanford.slac.archiverappliance.PB.data.PBV4GenericBytes.<init>(PBV4GenericBytes.java:78) ~[classes/:?]
at jdk.internal.reflect.DirectConstructorHandleAccessor.newInstance(DirectConstructorHandleAccessor.java:62) ~[?:?]
... 6 more
I would like to ask two questions:
1. What is the cause of this failure? I have attached the full error logs from AA engine.
2. Does the current stable version of Archiver Appliance fully support archiving user-defined custom PVA structure PVs?
Thanks a lot for any suggestions.
 Best regards,
Huihui
Prev: RE: Granville-Phillips 830 Vacuum Quality Monitor Wang, SuYin Grass via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026
ANJ, 30 Jun 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
