1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026
Subject: 回复: Re: Archiver Appliance cannot archive structured PV data
From: lvhh--- via Tech-talk <tech-talk at aps.anl.gov>
To: sky.brewer <sky.brewer at ess.eu>, tech-talk <tech-talk at aps.anl.gov>
Date: Fri, 3 Jul 2026 18:17:53 +0800
Hi all,
I have rewritten the DB file, which only contains one record inside the structure PV. The DB file is:
record(calc,"DEVITEST:shotID")
field(DESC,"shot ID counter")
field(SCAN,"2 second")
field(CALC,"A+I")
field(INPA,"DEVITEST:shotID.VAL NPP NMS")
field(VAL,"0")
field(TSE,"2")
info(0:group,
"DEVITEST:waveStruct":{
     "shot id":{+channel:"VAL"}
I use pva://DEVITEST:waveStruct to add to AA.
But this PV remains stuck in the initial sampling state, and no error logs are generated during the process.
Thanks a lot for any suggestions.
Best regards,
Huihui
lvhh at sari.ac.cn
发件人: Sky Brewer
发送时间: 2026-07-01 14:38
主题: Re: Archiver Appliance cannot archive structured PV data
Hi Huihui,
The archiver does support custom structures but they must follow the format https://github.com/epics-docs/epics-docs/pull/182/changes
Youll note here the timestamp, the timestamp is what looks to be the problem in the error log.
Hope that helps.
Sky
Sent from Outlook for Mac
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of 吕慧慧 via Tech-talk <tech-talk at aps.anl.gov>
Date: Wednesday, 1 July 2026 at 04:39
To: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Subject: Archiver Appliance cannot archive structured PV data
Hi all,
I have implemented a structured PVA data in an EPICS V7 IOC. The db is as follows:
record(longin, "DEV1:RED:SHOT_ID_TEST") {
    field(DTYP, "PSC Reg")
    field(INP , "@$(NAME) 526 2")
    field(SCAN, "I/O Intr")
    field(TSE , "-2")
    info(Q:group, {
        "DEV1:RED:WAVE_TEST_PVA": {
            "COUNT": {
                +channel:"VAL"
record(waveform, "DEV1:RED:WAVE_TEST_C1") {
    field(DTYP, "PSC Block I16 In")
    field(INP , "@$(NAME) 8193")
    field(FTVL, "DOUBLE")
    field(NELM, "20000000")
    info(Q:group,{
            "VALUE": {
                +channel:"VAL"
When I try to archive this PV using the pva://pvname prefix in Archiver Appliance, the archiver throws error messages  and cannot establish persistent archiving.
2026-06-30 15:48:19,766 ERROR [JCA Command Thread 9] pv.EPICS_V4_PV (EPICS_V4_PV.java:241) - Cannot determine the timestamp bitset for PV DEVI:RED:WAVE_TEST_PVA. This means we may not save any data at all for this PV
2026-06-30 15:48:19,767 ERROR [JCA Command Thread 9] pv.EPICS_V4_PV (EPICS_V4_PV.java:442) - exception when reading pv
java.lang.reflect.InvocationTargetException: null
at jdk.internal.reflect.DirectConstructorHandleAccessor.newInstance(DirectConstructorHandleAccessor.java:72) ~[?:?]
at java.lang.reflect.Constructor.newInstanceWithCaller(Constructor.java:502) ~[?:?]
at java.lang.reflect.Constructor.newInstance(Constructor.java:486) ~[?:?]
at org.epics.archiverappliance.engine.pv.EPICS_V4_PV.fromStructure(EPICS_V4_PV.java:278) ~[classes/:?]
at org.epics.archiverappliance.engine.pv.EPICS_V4_PV.subscribe(EPICS_V4_PV.java:438) ~[classes/:?]
at org.epics.archiverappliance.engine.pv.EPICS_V4_PV.handleConnected(EPICS_V4_PV.java:388) ~[classes/:?]
at org.epics.archiverappliance.engine.pv.JCACommandThread.run(JCACommandThread.java:194) [classes/:?]
Caused by: java.lang.NullPointerException: Cannot invoke "org.epics.vtype.PVStructure.getString()" because "timestampPVStructure" is null
at org.epics.archiverappliance.common.TimeUtils.convertFromPVTimestamp(TimeUtils.java:531) ~[classes/:?]
at edu.stanford.slac.archiverappliance.PB.data.PBV4GenericBytes.<init>(PBV4GenericBytes.java:78) ~[classes/:?]
at jdk.internal.reflect.DirectConstructorHandleAccessor.newInstance(DirectConstructorHandleAccessor.java:62) ~[?:?]
... 6 more
I would like to ask two questions:
1. What is the cause of this failure? I have attached the full error logs from AA engine.
2. Does the current stable version of Archiver Appliance fully support archiving user-defined custom PVA structure PVs?
 Best regards,
Huihui
Re: 回复: Re: Archiver Appliance cannot archive structured PV data Michael Davidsaver via Tech-talk
Archiver Appliance cannot archive structured PV data 吕慧慧 via Tech-talk
Re: Archiver Appliance cannot archive structured PV data Sky Brewer via Tech-talk
Prev: Re: AreaDetector Collaboration Meeting - July 2nd Mark Rivers via Tech-talk
Next: WEISS release 1.3.0 André Favoto via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026
Prev: Re: Archiver Appliance cannot archive structured PV data Sky Brewer via Tech-talk
Next: Re: 回复: Re: Archiver Appliance cannot archive structured PV data Michael Davidsaver via Tech-talk
ANJ, 06 Jul 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
