I can think of another idea to add: set field(PINI, “RUNNING”) instead of “YES”.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Varuna Crishan Meddage via Tech-talk <tech-talk at aps.anl.gov>
Date: Tuesday, June 9, 2026 at 09:30
To: Michael Davidsaver <mdavidsaver at gmail.com>
Cc: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Subject: Re: PVA OUT Links in EPICS:
Thank you.
From: Michael Davidsaver <mdavidsaver at gmail.com>
Sent: Monday, June 8, 2026 7:36 PM
To: Varuna Crishan Meddage <vmeddage at fnal.gov>
[EXTERNAL] – This message is from an external sender
On 6/8/26 4:13 PM, Varuna Crishan Meddage via Tech-talk wrote:
I tried different tricks for example setting field(VAL, "0") and field(PINI, "YES"), but none of them was successful.
I should also note that setting PINI to YES will leave this record with a INVALID LINK alarm as the PVA link is unlikely to be connected by the time of the initial process scan.
Depending on your desired reconnect behavior, you may wish to investigate the "retry" link option.
retry. For an output link, and
true (not default), then the most recent incomplete PUT will be re-tried when the target PV (re)connects.
- Re: PVA OUT Links in EPICS: Michael Davidsaver via Tech-talk
- PVA OUT Links in EPICS: Varuna Crishan Meddage via Tech-talk
- Re: PVA OUT Links in EPICS: Varuna Crishan Meddage via Tech-talk
Re: support for LXI devices (Bustec ProDAQ 6150 specifically) Michael Davidsaver via Tech-talk
2025
<2026>
2025
<2026>
ANJ, 13 Jul 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
