Hello, I am having a device communicating over Modbus/TCP with four analog input channel I am using these individual channels with ai records and SCAN in I/O Intr mode. These four channels are used as detector PV's in SScan record. I wanted to trigger the Detector acquisition only after all the four ai PV are processed (i.e. after I/o Intr processing of ai record). Is there any way to do this and can I get the time stamp of the modbus read/write operation. I am using EPICS 7 with modbus 3.3 asyn 4.42 streamdevice 2.8.22 Thank you in advance. Regards, Kuldeep
| ANJ, 12 Aug 2026 |
Home
News
About
Talk
Base
Modules
Extensions
