1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Best Practice for Global Module Configuration
From: "Blomley, Edmund \(IBPT\) via Tech-talk" <tech-talk at aps.anl.gov>
To: EPICS Tech Talk <tech-talk at aps.anl.gov>
Date: Tue, 6 Oct 2026 12:05:55 +0000
Hey all,
Let’s assume you are working on an EPICS module.
This module has a default string pattern it uses for a certain task.
This pattern can be overridden in the start-up script using a function provided by the module.
Now, if you want to use the same string pattern across all IOCs it would mean you would have to add the same line of code to each IOC.
Therefore I want to add a feature to the module itself which allows me to override the module default string.
But still have the option to define it on the IOC level to override.
There would be different options to achieve this. For example:
  • Please look this custom ENV variable
  • Please look at this custom filepath for file X
But how about defining the custom string pattern in the IOC configuration at build time? Would that make sense for such a scenario?
And if yes, how should/would it look like?
Would that be something I would add to the CONFIG_SITE meachanism, so one can use CONIFG_SITE.local?
Or would that be an unusual/unexpected? If yes, where and how would be a better approach?
If you need a more concrete example to understand the use-case:
Let’s imagine you are using the recaster module and want to define your exclude pattern globally for your whole site, but sometimes want certain IOCs to use a different pattern.
Cheers
eddy
Attachment: smime.p7s
Description: S/MIME cryptographic signature
Prev: Re: E3 conda recipe problem Jörn Dreyer via Tech-talk
Next: Should we expect monitor events for non-VAL fields on SEVR change? André Favoto via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
ANJ, 08 Oct 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
