1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: E3 conda recipe problem
From: Jörn Dreyer via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>, Simon Rose <Simon.Rose at ess.eu>
Date: Tue, 06 Oct 2026 11:49:25 +0200
Thanks Simon,
that solved the problem. I must have overlooked that detail :(
Do you know if there is still a way to install a vendor SDK from within the same package?
I need o install a header file and a library. In the Python e3-build-tools there was a way via VENDOR_LIBS and E3_MODULES_VENDOR_LIBS_LOCATION to achieve that.
But it seems not to be implemented anymore that way.
Jörn
Am Dienstag, 6. Oktober 2026, 09:35:57 Mitteleuropäische Sommerzeit schrieb Simon Rose:
> Hi Jörn -
> I’m not 100% certain, but looking at your syntax for selecting sources it seems that you need to separate the path from the git portion, something akin to
> source:
>   - git_url: git@XXXX:{{ name }}.git
>     git_rev: 2.2.2
>   - path: ../src
> See https://urldefense.us/v3/__https://docs.conda.io/projects/conda-build/en/stable/resources/define-metadata.html*source-from-multiple-sources__;Iw!!G_uCfscf7eWS!ecbVh7jVX6gM7h8fyzFPjeSoJMGLJA_5PjBvoQ4Xl0j0lCDRMWlabaFTeskXrdnI3dSiqrlz_xJtUxtiI__2PB8$
> Cheers,
> Simon
> From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Jörn Dreyer via Tech-talk <tech-talk at aps.anl.gov>
> Date: Tuesday, 6 October 2026 at 09:31
> To: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
> Subject: E3 conda recipe problem
> Hello,
> I am currently trying to create a recipe for one of my EPICS module to be installed using the E3 conda packaging methode.
> Due to the fact that my repository is currently private, I can not use the package download only the git source is available.
> My source definition in meta.yaml looks like:
> source:
>   git_rev: 2.2.2
>   path: ../src
> The download of the source works, but the Makefile from the src directory does not get copied to the build directory.
> What could be the reason for that?
> The result is that the original Makefile from my module is used to build and that fails at the stage of the ioc build.
> I tested with the recipe for iocstats as described in the documentation at https://urldefense.us/v3/__https://e3.pages.ess.eu/developer/recipes.html__;!!G_uCfscf7eWS!bU2qcFJwCiGcdtstMpr0jpSI5PGz1ZZYBlXQmJ2EbPRacIp1W9c_-lYHFJzMkBpShfaWY6_gACO-9ADKwRsKH6Y$ .
> This recipe works and copies the content of the src folder into the work folder of the build directory after exracting the source of the iocstats module.
> Jörn
Dr. Jörn Dreyer
HIBEF DAQ + Controls
Institut für Strahlenpysik
Helmholtz-Zentrum Dresden - Rossendorf e.V. (HZDR)
Bautzner Landstr. 400 | 01328 Dresden | Germany
https://urldefense.us/v3/__http://www.hzdr.de__;!!G_uCfscf7eWS!ecbVh7jVX6gM7h8fyzFPjeSoJMGLJA_5PjBvoQ4Xl0j0lCDRMWlabaFTeskXrdnI3dSiqrlz_xJtUxtiieS1t1k$
Vorstand: Prof. Dr. Sebastian M. Schmidt, Dr. Diana Stiller
Vereinsregister: VR 1693 beim Amtsgericht Dresden
BEGIN:VCARD
VERSION:3.0
EMAIL;TYPE:j.dreyer at hzdr.de
FN:Jörn Dreyer
N:Dreyer;Jörn;;;
ORG:Helmholtz - Zentrum Dresden- Rossendorf;FWKX
TEL;TYPE=WORK:+0493502603263
TITLE:Dr.
UID:c191707b-eb41-4699-bb8d-a5ef050ab4aa
X-KADDRESSBOOK-MailPreferedFormatting:TEXT
END:VCARD
E3 conda recipe problem Jörn Dreyer via Tech-talk
Re: E3 conda recipe problem Simon Rose via Tech-talk
Prev: Re: E3 conda recipe problem Simon Rose via Tech-talk
Next: Best Practice for Global Module Configuration Blomley, Edmund (IBPT) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
ANJ, 06 Oct 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
