Hello All,
Although I am new to this community, I have attempted to thoroughly investigate the problem before seeking assistance. My testing has included:
- Analysis of record status fields (PACT and related fields)
- Wireshark capture and comparison of successful and failed reconnect sequences
- Testing with and without @mismatch
- Protocol modifications to alter mismatch-handling behaviour
- Comparison of behaviour across multiple ports and devices
Based on these tests, I have been able to narrow the issue down considerably, but I am unsure whether my interpretation of the StreamDevice behaviour is correct.
I have a device which communicates with EPICS over TCP. A record sends a command to the device and then expects a response via the following protocol:
get_V { out "V\$1?";
in "V\$1=%f";
@mismatch {
out "V\$1?";
in "V\$1=%f";
If the Ethernet connection is lost and then re-established, I observe an erroneous "read 0". This causes the protocol to enter the @mismatch handler. At this point, the subsequent write from within the @mismatch block appears to fail and
I receive a writeRequest error.
My understanding is that the writeRequest error occurs because StreamDevice is attempting to write using a connection that no longer exists, although I am not certain that this interpretation is correct.
Ideally, I would like to specify in the protocol that both of the following are valid responses:
V1=<floating point value>
<blank>
where a blank response would simply return 0 (or otherwise be ignored) and allow processing to continue normally.
I came across the following discussion, which seemed potentially relevant:
"EPICS Re: Stream Device errors and record initialization"
Based on that discussion, I modified the protocol to:
in "%*{V\$1=|}%?f";
@mismatch {
out "V\$1?";
in "V\$1=%f";
This successfully handles the erroneous read following connection loss and recovery. However, it introduces a new concern. If the device were to return
an invalid response such as:
V1=ABC
the protocol appears to accept this as valid and simply return 0, whereas I would ideally like this to be treated as a genuine data error.
My goal is therefore to:
- Accept valid responses of the form V1(or other variable Vn) =<float>.
- Accept a blank response and continue processing without entering @mismatch.
- Reject malformed responses such as V1=ABC and allow them to be handled as errors.
Is there a recommended way to express this behaviour within a StreamDevice protocol?
David
