2012  <2013>  2014  2015  2016  2017  2018  2019  Index 2012  <2013>  2014  2015  2016  2017  2018  2019
Subject: epicsqt 2.5.0 released
To: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 4 Jun 2013 17:49:58 +1000
Dear all,
A new version of the EPICS Qt Framework has been released and is available at https://sourceforge.net/projects/epicsqt/.
The default download and associated documentation is now for 2.5.0. Earlier versions are still available.
This version includes the following changes:
   - Addition of new QE widgets: QENumericEdit, QECheckBox, QERadioGroup.
   - Expand documentation (reference and guide).
   - Reduce startup time for embedded sub forms.
   - Display various information in 'Help->About' including macro substitutions, search paths, open files, version numbers of application, libraries and plugins.
   - Add persistence management. Configurations such as window layout can be saved and restored at any time including startup.
   - Add QEGui application logo.
   - QEGui executable is now named qegui.
   - Allow multiple gui files to be opened on startup.
   - QEGui has display scaling capability (-a startup parameter).
   - Add application wide user level passwords. Implemented in QEGui.
   - If QELogin widget is used in an application that does not use this feature, the QELogin widget maintains its own local passwords as before.
   - QERadionButton and QECheckBox now defaults to write "1" when checked and "0" when unchecked.
   - QEGui path list now uses : or ; (depending on platform) to sperate paths so spaces can be used within paths.
   - Bug fixes and minor enhancements. (See detailed log in release notes).
Enjoy,
Andrew Rhyder
SUPPLIERS: As of 1 January 2013, the Australian Synchrotron Company Ltd has changed its business name. However, the trading name will remain Australian Synchrotron.
Please address all quotations and invoices to: Synchrotron Light Source Australia Pty Ltd (SLSA), ABN: 18 159 468 256
Prev: RE: Qt/QE Framework and CheckBoxes Andrew Rhyder
Next: caQtDM V3.1.1 Mezger Anton Christian
Index: 2012  <2013>  2014  2015  2016  2017  2018  2019
ANJ, 26 Jun 2013 · Home · News · About · Talk · Base · Modules · Extensions ·
