2012  <2013>  2014  2015  2016  2017  2018  2019  Index 2012  <2013>  2014  2015  2016  2017  2018  2019
Subject: caQtDM V3.1.1
To: <[email protected]>, <[email protected]>
Date: Wed, 26 Jun 2013 13:13:06 +0200
Dear all,
A new version of caQtDM (V3.1.1) can be found at our PSI-Website http://epics.web.psi.ch/software/caqtdm/
The main characteristic of this version is that you can resize the caQtDM synoptic display windows without using Qt layouts. You can build a display normally and everything will be resized when you resize the window.
In order to make the resizing correctly, you should specify for the fontscalemode of caLabel and caLineEdit the parameter "WidthAndHeight". When you convert MEDM displays with the utility adl2ui, this is done automatically.
When you do not want a window to be resized, you can specify -noResize on the command line.
Another enhancement existing since version 2.8 is the fact that you can hook a digit of the wheelswitch to the keyboard in order to modify it with the up and down keys.
Also a windows distribution package is available. This package allows you to use the Qt designer, caQtDM with EPICS immediately after installing.
For linux, you could use the shell script caQtDM_Build for building the package. However you should install Qt and Qwt before. For SL6 32 bit images are also included
Let me know of its usage, improvements, bug fixes, hints. Tell me if you like it.
Dr. Anton Chr. Mezger
Head of Accelerator Operations
Accelerator division   (ABE)
Paul Scherrer Institut, WBGB/103
CH-5323 Villigen PSI
E-Mail:   [email protected]
Phone:  ++41 (0)56 310 3406
Fax :      ++41 (0)56 310 3383
Prev: epicsqt 2.5.0 released Andrew Rhyder
Next: Apologies for mailman issue Andrew Johnson
Index: 2012  <2013>  2014  2015  2016  2017  2018  2019
ANJ, 03 Jul 2013 · Home · News · About · Talk · Base · Modules · Extensions ·
