2012  <20132014  2015  2016  2017  2018  2019  Index 2012  <20132014  2015  2016  2017  2018  2019
Subject: RE: epicsqt with Qt5.1.1, Qt-Creator 2.8.1
To: "Alexander S. Aryshev" <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 16 Oct 2013 10:04:28 -0700
epicsqt is build on Qt4
although the Qt4 to Qt5 migration should be simple,
I recommend you first try your installation on Qt4.
PS: I am not an epicsqt developer!
Emmanuel
> Date: Tue, 15 Oct 2013 19:35:16 -0700
> From: [email protected]
> To: [email protected]
> Subject: epicsqt with Qt5.1.1, Qt-Creator 2.8.1
> Dear QTi-talk,
> I am trying to compile epicsqt 2.7.1 with
> very standard installation of Qt5.1.1 and install
> its plugin into designer under Qt-creator 2.8.1 on
> Scientific Linux 6.4 (kernel 2.6.32-358.18.1.el6.i686).
> The Creator itself was build from src under the same version of Qt.
> The QWT version is 6.1.0. It was also build from src and seems
> working ok (all examples are working fine).
> EPICS base3.14.12.3 is installed and all env. variables are defined.
> After all standard changes http://qt-project.org/wiki/Transition_from_Qt_4.x_to_Qt5
> applied to epicsqt 2.7.1 it was built without any errors
> (just warnings about QE_ARCHIVE_LIST is not defined).
> After that I have defined QT_PLUGIN_PATH pointed to framework folder
> where designer folder with libQEPlugin.so was.
> Unfortunately this library always return
> "Plugin verification data mismatch" on loading.
> Does anyone had a similar problem and know how to solve it?
> Below is a list of my environment.
> With the best regards,
> Alex
> Qt 5.1.1 (Qt-5.1.1)
> ABI: x86-linux-generic-elf-32bit
> Source: /usr/local/Qt-5.1.1
> mkspec: linux-g++
> qmake: /usr/local/Qt-5.1.1/bin/qmake
> Version: 5.1.1
> QMAKE_SPEC linux-g++
> QMAKE_VERSION 3.0
> QMAKE_XSPEC linux-g++
> QT_HOST_BINS /usr/local/Qt-5.1.1/bin
> QT_HOST_DATA /usr/local/Qt-5.1.1
> QT_HOST_LIBS /usr/local/Qt-5.1.1/lib
> QT_HOST_PREFIX /usr/local/Qt-5.1.1
> QT_INSTALL_ARCHDATA /usr/local/Qt-5.1.1
> QT_INSTALL_BINS /usr/local/Qt-5.1.1/bin
> QT_INSTALL_CONFIGURATION /usr/local/Qt-5.1.1/etc/xdg
> QT_INSTALL_DATA /usr/local/Qt-5.1.1
> QT_INSTALL_DEMOS /usr/local/Qt-5.1.1/examples
> QT_INSTALL_DOCS /usr/local/Qt-5.1.1/doc
> QT_INSTALL_EXAMPLES /usr/local/Qt-5.1.1/examples
> QT_INSTALL_HEADERS /usr/local/Qt-5.1.1/include
> QT_INSTALL_IMPORTS /usr/local/Qt-5.1.1/imports
> QT_INSTALL_LIBEXECS /usr/local/Qt-5.1.1/libexec
> QT_INSTALL_LIBS /usr/local/Qt-5.1.1/lib
> QT_INSTALL_PLUGINS /usr/local/Qt-5.1.1/plugins
> QT_INSTALL_PREFIX /usr/local/Qt-5.1.1
> QT_INSTALL_QML /usr/local/Qt-5.1.1/qml
> QT_INSTALL_TESTS /usr/local/Qt-5.1.1/tests
> QT_INSTALL_TRANSLATIONS /usr/local/Qt-5.1.1/translations
> QT_SYSROOT
> QT_VERSION 5.1.1
> gcc -v
> Using built-in specs.
> COLLECT_GCC=gcc
> COLLECT_LTO_WRAPPER=/usr/local/libexec/gcc/i686-pc-linux-gnu/4.8.1/lto-wrapper
> Target: i686-pc-linux-gnu
> Configured with: ./configure
> Thread model: posix
> gcc version 4.8.1 (GCC)
Re: epicsqt with Qt5.1.1, Qt-Creator 2.8.1 Alexander S. Aryshev
Prev: epicsqt with Qt5.1.1, Qt-Creator 2.8.1 Alexander S. Aryshev
Next: Re: epicsqt with Qt5.1.1, Qt-Creator 2.8.1 Jennings Guy
Index: 2012  <20132014  2015  2016  2017  2018  2019
Next: Re: epicsqt with Qt5.1.1, Qt-Creator 2.8.1 Alexander S. Aryshev
ANJ, 17 Oct 2013 · Home · News · About · Talk · Base · Modules · Extensions ·
