2012  2013  2014  <2015>  2016  2017  2018  2019  Index 2012  2013  2014  <2015>  2016  2017  2018  2019
Subject: Re: Any example EDM files that work with the new converter: "edl2ui" ?
From: "Ebner Simon Gregor (PSI)" <[email protected]>
To: "Williams Jr., Ernest L." <[email protected]>
Cc: "[email protected]" <[email protected]>, "Babbitt, Alisha" <[email protected]>
Date: Wed, 11 Mar 2015 07:21:36 +0000
Hello Ernest
Sorry no, I am not aware of any EDM files that I can use to check the converter.
If you send me some I can test on our infrastructure.
Cheers
Simon
> On 10 Mar 2015, at 03:47, Williams Jr., Ernest L. <[email protected]> wrote:
> Hi Simon,
> Do you have any EDM files in the distribution or else where that we can try your conversion tool?
> Every attempt made so far crashes badly :(
> [ernesto@icd-pc90626 display]$ edl2ui ioc_stats_soft.edl
> edl2ui -- file = <ioc_stats_soft.edl>
> edl2ui -- file <stylesheet.qss> found and will be integrated in the resulting ui file
> edl2ui -- if you do not want any styles, redefine CAQTDM_DISPLAY_PATH
> read in file <ioc_stats_soft.edl>
> *** buffer overflow detected ***: edl2ui terminated
> ======= Backtrace: =========
> /lib64/libc.so.6(__fortify_fail+0x37)[0x3fbbf02527]
> /lib64/libc.so.6[0x3fbbf00410]
> /lib64/libc.so.6(__strncpy_chk+0x17b)[0x3fbbeff6db]
> edl2ui[0x41182b]
> edl2ui[0x411bdf]
> edl2ui[0x406add]
> /lib64/libc.so.6(__libc_start_main+0xfd)[0x3fbbe1ed5d]
> edl2ui[0x4026e9]
> ======= Memory map: ========
> 00400000-00421000 r-xp 00000000 00:585 1861523150                        /afs/slac.stanford.edu/g/lcls/vol8/epics/R3-14-12-4_1-0/extensions/extensions-R3-14-12/bin/linux-x86_64/edl2ui
> 00621000-00622000 rw-p 00021000 00:585 1861523150                        /afs/slac.stanford.edu/g/lcls/vol8/epics/R3-14-12-4_1-0/extensions/extensions-R3-14-12/bin/linux-x86_64/edl2ui
> 017c9000-017ea000 rw-p 00000000 00:00 0                                  [heap]
> 3fbba00000-3fbba20000 r-xp 00000000 08:01 1571116                        /lib64/ld-2.12.so
> 3fbbc1f000-3fbbc20000 r--p 0001f000 08:01 1571116                        /lib64/ld-2.12.so
> 3fbbc20000-3fbbc21000 rw-p 00020000 08:01 1571116                        /lib64/ld-2.12.so
> 3fbbc21000-3fbbc22000 rw-p 00000000 00:00 0
> 3fbbe00000-3fbbf8a000 r-xp 00000000 08:01 1573308                        /lib64/libc-2.12.so
> 3fbbf8a000-3fbc18a000 ---p 0018a000 08:01 1573308                        /lib64/libc-2.12.so
> 3fbc18a000-3fbc18e000 r--p 0018a000 08:01 1573308                        /lib64/libc-2.12.so
> 3fbc18e000-3fbc18f000 rw-p 0018e000 08:01 1573308                        /lib64/libc-2.12.so
> 3fbc18f000-3fbc194000 rw-p 00000000 00:00 0
> 3fbc200000-3fbc283000 r-xp 00000000 08:01 1580774                        /lib64/libm-2.12.so
> 3fbc283000-3fbc482000 ---p 00083000 08:01 1580774                        /lib64/libm-2.12.so
> 3fbc482000-3fbc483000 r--p 00082000 08:01 1580774                        /lib64/libm-2.12.so
> 3fbc483000-3fbc484000 rw-p 00083000 08:01 1580774                        /lib64/libm-2.12.so
> 3fbc600000-3fbc617000 r-xp 00000000 08:01 1590083                        /lib64/libpthread-2.12.so
> 3fbc617000-3fbc817000 ---p 00017000 08:01 1590083                        /lib64/libpthread-2.12.so
> 3fbc817000-3fbc818000 r--p 00017000 08:01 1590083                        /lib64/libpthread-2.12.so
> 3fbc818000-3fbc819000 rw-p 00018000 08:01 1590083                        /lib64/libpthread-2.12.so
> 3fbc819000-3fbc81d000 rw-p 00000000 00:00 0
> 3fbca00000-3fbca02000 r-xp 00000000 08:01 1590088                        /lib64/libdl-2.12.so
> 3fbca02000-3fbcc02000 ---p 00002000 08:01 1590088                        /lib64/libdl-2.12.so
> 3fbcc02000-3fbcc03000 r--p 00002000 08:01 1590088                        /lib64/libdl-2.12.so
> 3fbcc03000-3fbcc04000 rw-p 00003000 08:01 1590088                        /lib64/libdl-2.12.so
> 3fbce00000-3fbce15000 r-xp 00000000 08:01 1580780                        /lib64/libz.so.1.2.3
> 3fbce15000-3fbd014000 ---p 00015000 08:01 1580780                        /lib64/libz.so.1.2.3
> 3fbd014000-3fbd015000 r--p 00014000 08:01 1580780                        /lib64/libz.so.1.2.3
> 3fbd015000-3fbd016000 rw-p 00015000 08:01 1580780                        /lib64/libz.so.1.2.3
> 3fbd200000-3fbd207000 r-xp 00000000 08:01 1590221                        /lib64/librt-2.12.so
> 3fbd207000-3fbd406000 ---p 00007000 08:01 1590221                        /lib64/librt-2.12.so
> 3fbd406000-3fbd407000 r--p 00006000 08:01 1590221                        /lib64/librt-2.12.so
> 3fbd407000-3fbd408000 rw-p 00007000 08:01 1590221                        /lib64/librt-2.12.so
> 3fbd600000-3fbd715000 r-xp 00000000 08:01 1590399                        /lib64/libglib-2.0.so.0.2800.8
> 3fbd715000-3fbd915000 ---p 00115000 08:01 1590399                        /lib64/libglib-2.0.so.0.2800.8
> 3fbd915000-3fbd916000 rw-p 00115000 08:01 1590399                        /lib64/libglib-2.0.so.0.2800.8
> 3fbd916000-3fbd917000 rw-p 00000000 00:00 0
> 3fbe200000-3fbe204000 r-xp 00000000 08:01 1591015                        /lib64/libgthread-2.0.so.0.2800.8
> 3fbe204000-3fbe403000 ---p 00004000 08:01 1591015                        /lib64/libgthread-2.0.so.0.2800.8
> 3fbe403000-3fbe404000 rw-p 00003000 08:01 1591015                        /lib64/libgthread-2.0.so.0.2800.8
> 3fbe600000-3fbe64a000 r-xp 00000000 08:01 1591040                        /lib64/libgobject-2.0.so.0.2800.8
> 3fbe64a000-3fbe849000 ---p 0004a000 08:01 1591040                        /lib64/libgobject-2.0.so.0.2800.8
> 3fbe849000-3fbe84b000 rw-p 00049000 08:01 1591040                        /lib64/libgobject-2.0.so.0.2800.8
> 3fbe84b000-3fbe84c000 rw-p 00000000 00:00 0
> 3fbea00000-3fbea1d000 r-xp 00000000 08:01 1337252                        /usr/lib64/libxcb.so.1.1.0
> 3fbea1d000-3fbec1d000 ---p 0001d000 08:01 1337252                        /usr/lib64/libxcb.so.1.1.0
> 3fbec1d000-3fbec1e000 rw-p 0001d000 08:01 1337252                        /usr/lib64/libxcb.so.1.1.0
> 3fbee00000-3fbee02000 r-xp 00000000 08:01 1333855                        /usr/lib64/libXau.so.6.0.0
> 3fbee02000-3fbf002000 ---p 00002000 08:01 1333855                        /usr/lib64/libXau.so.6.0.0
> 3fbf002000-3fbf003000 rw-p 00002000 08:01 1333855                        /usr/lib64/libXau.so.6.0.0
> 3fbf200000-3fbf337000 r-xp 00000000 08:01 1337407                        /usr/lib64/libX11.so.6.3.0
> 3fbf337000-3fbf537000 ---p 00137000 08:01 1337407                        /usr/lib64/libX11.so.6.3.0
> 3fbf537000-3fbf53d000 rw-p 00137000 08:01 1337407                        /usr/lib64/libX11.so.6.3.0
> 3fbf600000-3fbf611000 r-xp 00000000 08:01 1337482                        /usr/lib64/libXext.so.6.4.0
> 3fbf611000-3fbf811000 ---p 00011000 08:01 1337482                        /usr/lib64/libXext.so.6.4.0
> 3fbf811000-3fbf812000 rw-p 00011000 08:01 1337482                        /usr/lib64/libXext.so.6.4.0
> 3fbfa00000-3fbfa26000 r-xp 00000000 08:01 1582693                        /lib64/libexpat.so.1.5.2
> 3fbfa26000-3fbfc25000 ---p 00026000 08:01 1582693                        /lib64/libexpat.so.1.5.2
> 3fbfc25000-3fbfc28000 rw-p 00025000 08:01 1582693                        /lib64/libexpat.so.1.5.2Aborted
> Cheers,
> Ernest
Any example EDM files that work with the new converter: "edl2ui" ? Williams Jr., Ernest L.
Prev: Any example EDM files that work with the new converter: "edl2ui" ? Williams Jr., Ernest L.
Next: Re: Any example EDM files that work with the new converter: "edl2ui" ? Kevin Peterson
Index: 2012  2013  2014  <2015>  2016  2017  2018  2019
