2012  2013  2014  <2015>  2016  2017  2018  2019  Index 2012  2013  2014  <2015>  2016  2017  2018  2019
Subject: RE: Any example EDM files that work with the new converter: "edl2ui" ?
From: "Williams Jr., Ernest L." <[email protected]>
To: "Mezger Anton Christian (PSI)" <[email protected]>, Kevin Peterson <[email protected]>, "Ebner Simon Gregor (PSI)" <[email protected]>
Cc: "[email protected]" <[email protected]>, "Babbitt, Alisha" <[email protected]>
Date: Thu, 12 Mar 2015 01:17:38 +0000
Hi everyone,
This morning we ran the gdb debugger and found an issue with "parserClass.cc"
I think that Zai may have addressed it now.
We will try his new file.
Cheers,
Ernest
From: Mezger Anton Christian (PSI) [[email protected]]
Sent: Wednesday, March 11, 2015 10:00 AM
To: Kevin Peterson; Williams Jr., Ernest L.; Ebner Simon Gregor (PSI)
Cc: [email protected]; Babbitt, Alisha
Hi Kevin,
probably you are hitting classes that are not (yet) integrated. We had only very simple edl files in our house, so you should take a look at the code and integrate the unknown classes or skip them. Should be quite easy.
Best regards
Anton
-----Original Message-----
Sent: Mittwoch, 11. März 2015 17:56
To: Williams Jr., Ernest L.; Ebner Simon Gregor (PSI); Mezger Anton Christian (PSI)
Subject: Re: Any example EDM files that work with the new converter: "edl2ui" ?
I'm able to convert ADBase.edl from ADCore without crashing edl2ui.
There are, however, many error messsages:
$ edl2ui ADBase.edl
edl2ui -- file = <ADBase.edl>
edl2ui -- file <stylesheet.qss> found and will be integrated in the resulting ui file edl2ui -- if you do not want any styles, redefine CAQTDM_DISPLAY_PATH read in file <ADBase.edl>
major=4 minor=0 release=1
Line 822, Error creating object "TextupdateClass"
Cannot find tag: beginObjectProperties, near line 823 Cannot find tag: major, near line 824 Cannot find tag: minor, near line 825 Cannot find tag: release, near line 826 Cannot find tag: x, near line 827 Cannot find tag: y, near line 828 Cannot find tag: w, near line 829 Cannot find tag: h, near line 830 Cannot find tag: controlPv, near line 831 Cannot find tag: fgColor, near line 832 Cannot find tag: fgAlarm, near line 833 Cannot find tag: bgColor, near line 834 Cannot find tag: fill, near line 835 Cannot find tag: font, near line 836 Cannot find tag: fontAlign, near line 837 Line 841, Error creating object "TextupdateClass"
Cannot find tag: beginObjectProperties, near line 842 Cannot find tag: major, near line 843 Cannot find tag: minor, near line 844 Cannot find tag: release, near line 845 Cannot find tag: x, near line 846 Cannot find tag: y, near line 847 Cannot find tag: w, near line 848 Cannot find tag: h, near line 849 Cannot find tag: controlPv, near line 850 Cannot find tag: fgColor, near line 851 Cannot find tag: fgAlarm, near line 852 Cannot find tag: bgColor, near line 853 Cannot find tag: fill, near line 854 Cannot find tag: font, near line 855 Cannot find tag: fontAlign, near line 856 Line 860, Error creating object "TextupdateClass"
Cannot find tag: beginObjectProperties, near line 861 Cannot find tag: major, near line 862 Cannot find tag: minor, near line 863 Cannot find tag: release, near line 864 Cannot find tag: x, near line 865 Cannot find tag: y, near line 866 Cannot find tag: w, near line 867 Cannot find tag: h, near line 868 Cannot find tag: controlPv, near line 869 Cannot find tag: fgColor, near line 870 Cannot find tag: fgAlarm, near line 871 Cannot find tag: bgColor, near line 872 Cannot find tag: fill, near line 873 Cannot find tag: font, near line 874 Cannot find tag: fontAlign, near line 875 Line 1113, Error creating object "TextupdateClass"
Cannot find tag: beginObjectProperties, near line 1114 Cannot find tag: major, near line 1115 Cannot find tag: minor, near line 1116 Cannot find tag: release, near line 1117 Cannot find tag: x, near line 1118 Cannot find tag: y, near line 1119 Cannot find tag: w, near line 1120 Cannot find tag: h, near line 1121 Cannot find tag: controlPv, near line 1122 Cannot find tag: fgColor, near line 1123 Cannot find tag: fgAlarm, near line 1124 Cannot find tag: bgColor, near line 1125 Cannot find tag: fill, near line 1126 Cannot find tag: font, near line 1127 Cannot find tag: fontAlign, near line 1128 Line 1132, Error creating object "TextupdateClass"
Cannot find tag: beginObjectProperties, near line 1133 Cannot find tag: major, near line 1134 Cannot find tag: minor, near line 1135 Cannot find tag: release, near line 1136 Cannot find tag: x, near line 1137 Cannot find tag: y, near line 1138 Cannot find tag: w, near line 1139 Cannot find tag: h, near line 1140 Cannot find tag: controlPv, near line 1141 Cannot find tag: fgColor, near line 1142 Cannot find tag: fgAlarm, near line 1143 Cannot find tag: bgColor, near line 1144 Cannot find tag: fill, near line 1145 Cannot find tag: font, near line 1146 Cannot find tag: fontAlign, near line 1147 Line 1170, Error creating object "TextupdateClass"
Cannot find tag: beginObjectProperties, near line 1171 Cannot find tag: major, near line 1172 Cannot find tag: minor, near line 1173 Cannot find tag: release, near line 1174 Cannot find tag: x, near line 1175 Cannot find tag: y, near line 1176 Cannot find tag: w, near line 1177 Cannot find tag: h, near line 1178 Cannot find tag: controlPv, near line 1179 Cannot find tag: fgColor, near line 1180 Cannot find tag: fgAlarm, near line 1181 Cannot find tag: bgColor, near line 1182 Cannot find tag: fill, near line 1183 Cannot find tag: font, near line 1184 Cannot find tag: fontAlign, near line 1185 Line 1343, Error creating object "ByteClass"
Cannot find tag: beginObjectProperties, near line 1344 Cannot find tag: major, near line 1345 Cannot find tag: minor, near line 1346 Cannot find tag: release, near line 1347 Cannot find tag: x, near line 1348 Cannot find tag: y, near line 1349 Cannot find tag: w, near line 1350 Cannot find tag: h, near line 1351 Cannot find tag: controlPv, near line 1352 Cannot find tag: lineColor, near line 1353 Cannot find tag: onColor, near line 1354 Cannot find tag: offColor, near line 1355 Cannot find tag: lineWidth, near line 1356 Cannot find tag: numBits, near line 1357 Line 1428, Error creating object "TextupdateClass"
Cannot find tag: beginObjectProperties, near line 1429 Cannot find tag: major, near line 1430 Cannot find tag: minor, near line 1431 Cannot find tag: release, near line 1432 Cannot find tag: x, near line 1433 Cannot find tag: y, near line 1434 Cannot find tag: w, near line 1435 Cannot find tag: h, near line 1436 Cannot find tag: controlPv, near line 1437 Cannot find tag: fgColor, near line 1438 Cannot find tag: fgAlarm, near line 1439 Cannot find tag: bgColor, near line 1440 Cannot find tag: fill, near line 1441 Cannot find tag: font, near line 1442 Cannot find tag: fontAlign, near line 1443 Line 1564, Error creating object "TextupdateClass"
Cannot find tag: beginObjectProperties, near line 1565 Cannot find tag: major, near line 1566 Cannot find tag: minor, near line 1567 Cannot find tag: release, near line 1568 Cannot find tag: x, near line 1569 Cannot find tag: y, near line 1570 Cannot find tag: w, near line 1571 Cannot find tag: h, near line 1572 Cannot find tag: controlPv, near line 1573 Cannot find tag: fgColor, near line 1574 Cannot find tag: fgAlarm, near line 1575 Cannot find tag: bgColor, near line 1576 Cannot find tag: fill, near line 1577 Cannot find tag: font, near line 1578 Cannot find tag: fontAlign, near line 1579 Line 1644, Error creating object "activeGroupClass"
Cannot find tag: beginObjectProperties, near line 1645 Cannot find tag: major, near line 1646 Cannot find tag: minor, near line 1647 Cannot find tag: release, near line 1648 Cannot find tag: x, near line 1649 Cannot find tag: y, near line 1650 Cannot find tag: w, near line 1651 Cannot find tag: h, near line 1652 Cannot find tag: beginGroup, near line 1654 Cannot find tag: object, near line 1657 Cannot find tag: beginObjectProperties, near line 1658 Cannot find tag: major, near line 1659 Cannot find tag: minor, near line 1660 Cannot find tag: release, near line 1661 Cannot find tag: x, near line 1662 Cannot find tag: y, near line 1663 Cannot find tag: w, near line 1664 Cannot find tag: h, near line 1665 Cannot find tag: controlPv, near line 1666 Cannot find tag: fgColor, near line 1667 Cannot find tag: fgAlarm, near line 1668 Cannot find tag: bgColor, near line 1669 Cannot find tag: fill, near line 1670 Cannot find tag: font, near line 1671 Unknown tag name: [endGroup]
Here is the URL to ADBase.edl:
https://raw.githubusercontent.com/areaDetector/ADCore/master/ADApp/op/edl/ADBase.edl
Kevin
Any example EDM files that work with the new converter: "edl2ui" ? Williams Jr., Ernest L.
Re: Any example EDM files that work with the new converter: "edl2ui" ? Kevin Peterson
RE: Any example EDM files that work with the new converter: "edl2ui" ? Mezger Anton Christian (PSI)
Prev: RE: Any example EDM files that work with the new converter: "edl2ui" ? Mezger Anton Christian (PSI)
Next: RE: EPICS QT and the CA archiver (INSTALLATION Instructions) Williams Jr., Ernest L.
Index: 2012  2013  2014  <2015>  2016  2017  2018  2019
