2012  2013  2014  <20152016  2017  2018  2019  Index 2012  2013  2014  <20152016  2017  2018  2019
Subject: RE: EPICS CA Interface for caQtDM and epicsqt
From: "Mezger Anton Christian (PSI)" <[email protected]>
To: "Williams Jr., Ernest L." <[email protected]>, "[email protected]" <[email protected]>
Cc: "Shankar, Murali" <[email protected]>, "[email protected]" <[email protected]>, "Babbitt, Alisha" <[email protected]>
Date: Tue, 17 Mar 2015 07:35:40 +0000
Dear All,
caQtDM and epicsqt have a different philosophy concerning the data io. caQtDM uses pure graphics objects that are populated by the caQtDM viewer. Epicsqt uses epics aware widgets, i.e epics is sitting underneath the widgets. Epicqt can view therefore the variables in the designer and the graphical widgets of caQtDM cannot. The two packages can be concurrent, while they consist of plugins for the designer. The viewer of both packages can thus use both widget sets. It is already some time ago that the integration of both widgets took place. It is however not impossible that after a year, things diverged. I think that related displays are not (well?) supported by the epicsqt viewer (Andrew, please correct me). If you use this feature of caQtDM, then use the caQtDM viewer and plugin the epicsqt widgets.
I hope this explanation helps you.
Best regards
Anton
-----Original Message-----
From: Williams Jr., Ernest L. [mailto:[email protected]]
Sent: Montag, 16. März 2015 21:08
To: Mezger Anton Christian (PSI); [email protected]
Cc: Babbitt, Alisha; Szalata, Zenon M.; Shankar, Murali; Williams Jr., Ernest L.; [email protected]
Subject: EPICS CA Interface for caQtDM and epicsqt
Hi Guys,
Can you tell us a bit about the Channel Access interface you have for your package?
Is it the same for both  "caQtDM" and "epicsqt" ?
If not, how is it different?
Thanks in advance for your time.
Cheers,
Ernest
RE: EPICS CA Interface for caQtDM and epicsqt Williams Jr., Ernest L.
RE: EPICS CA Interface for caQtDM and epicsqt Andrew Rhyder
Prev: RE: epicsqt compile error Zai Wang
Next: RE: EPICS CA Interface for caQtDM and epicsqt Williams Jr., Ernest L.
Index: 2012  2013  2014  <20152016  2017  2018  2019
Prev: EPICS CA Interface for caQtDM and epicsqt Williams Jr., Ernest L.
