2012  2013  2014  <20152016  2017  2018  2019  Index 2012  2013  2014  <20152016  2017  2018  2019
Subject: RE: epicsqt compile error
To: "Williams Jr., Ernest L." <[email protected]>
Cc: "[email protected]" <[email protected]>, "Babbitt, Alisha" <[email protected]>
Date: Tue, 17 Mar 2015 00:31:54 +0000
Hi Ernest,
EpicsQt and caQtDM are separate qt-based frameworks.
I think that QWTINCLUDE is used by caQtDM and QWT_INCLUDE_PATH is used by EpicsQt.
There is a bit integration going on. It might confuse you.
BTW, I just give you a bit help or input as I have a very good knowledge of both.
Don't send me any change/issue/suggestion to me please.
You may know:
Andrew is the main contact on epicsqt.
Anton is the main contact on caQtDM.
Emmanuel is the main contact on Epics Qt collaboration.
Cheers
Zai
-----Original Message-----
From: Williams Jr., Ernest L. [mailto:[email protected]]
Sent: Tuesday, 17 March 2015 11:02 AM
To: Zai Wang
Cc: Babbitt, Alisha; Williams Jr., Ernest L.; [email protected]
Hi Zai,
The actual problem is the the epicsqt package uses two different variables for the same thing.
framework uses:
# The following QWT include path and library path are only required if INCLUDEPATH += $$(QWT_INCLUDE_PATH)
But Applications uses:
$(QWTINCLUDE)
So, I set  "QWTINCLUDE"   to  "QWT_INCLUDE_PATH"
The Getting started Guide only talks about setting:   "QWT_INCLUDE_PATH"
Alisha will send out a diff file and patch for the changes we made.
Then you can consider them for inclusion into your next release.
Cheers,
Ernest
Sent: Monday, March 16, 2015 4:06 PM
To: Williams Jr., Ernest L.
Hi Ernest
You might mix up with caQtDM. They have different ENV variables for the same libs. It may be easy to use other PC or virtual box without caQtDM at start.
Then you check the make log msgs to see if any error.
Note: the below log complains caQtDM no qwt include path defined.
Cheers
Zai
Subject:
"Williams Jr., Ernest L." <[email protected]<mailto:ernesto_at_slac.stanford.edu>>
To:
"[email protected]<mailto:Andrew.Rhyder_at_synchrotron.org.au>" <[email protected]<mailto:Andrew.Rhyder_at_synchrotron.org.au>>
Cc:
"[email protected]<mailto:qti-talk_at_aps.anl.gov>" <[email protected]<mailto:qti-talk_at_aps.anl.gov>>, "Babbitt, Alisha" <[email protected]<mailto:ababbitt_at_slac.stanford.edu>>, "Williams Jr., Ernest L." <[email protected]<mailto:ernesto_at_slac.stanford.edu>>
Date:
Mon, 16 Mar 2015 16:24:22 +0000
Hi Andrew,
I definitely have QWT installed
I used QWT to actually build caQtDM.
[ernesto@icd-pc90626 qwt-6.0.1]$ env |grep QWT
QWT_INCLUDE_PATH=/afs/slac/g/lcls/package/qwt-6.0.1/include
QWT_ROOT=/afs/slac/g/lcls/package/qwt-6.0.1
However, when attempting to build epicsqt, I get the following error:
cd applications/QEGuiApp/ && make -f Makefile
make[1]: Entering directory `/afs/slac.stanford.edu/g/lcls/vol8/epics/R3-14-12-4_1-0/extensions/extensions-R3-14-12/src/epicsQt/epicsQt-R3-0-2/applications/QEGuiApp'
make -f Makefile.Release
make[2]: Entering directory `/afs/slac.stanford.edu/g/lcls/vol8/epics/R3-14-12-4_1-0/extensions/extensions-R3-14-12/src/epicsQt/epicsQt-R3-0-2/applications/QEGuiApp'
g++ -c -m64 -pipe -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -m64 -mtune=generic -D_REENTRANT -Wall -W -DQE_USE_CAQTDM -DQT_NO_DEBUG -DQT_SCRIPT_LIB -DQT_XML_LIB -DQT_GUI_LIB -DQT_NETWORK_LIB -DQT_CORE_LIB -I/usr/lib64/qt4/mkspecs/linux-g++-64 -I. -I/usr/include/QtUiTools -I/usr/include/QtDesigner -I/usr/include/QtCore -I/usr/include/QtNetwork -I/usr/include/QtGui -I/usr/include/QtXml -I/usr/include/QtScript -I/usr/include -IO.linux-x86_64/ui_headers -I. -Iinclude -I../../framework/widgets/QEWidget -I../../framework/widgets/QEForm -I../../framework/widgets/QELogin -I../../framework/data -I../../framework/api -I../../framework/common -I../../../../caQtDM/caQtDM-R3-8-10/caQtDM_Lib/src -I../../../../caQtDM/caQtDM-R3-8-10/caQtDM_QtControls/src -I -IO.linux-x86_64/moc -IO.linux-x86_64/ui_headers -o O.linux-x86_64/obj/main.o src/main.cpp        !
In file included from ../../../../caQtDM/caQtDM-R3-8-10/caQtDM_Lib/src/limitsStripplotDialog.h:45,
                 from ../../../../caQtDM/caQtDM-R3-8-10/caQtDM_Lib/src/caqtdm_lib.h:68,
                 from include/MainWindow.h:52,
                 from include/QEGui.h:32,
                 from src/main.cpp:27:
RE: epicsqt compile error Williams Jr., Ernest L.
Prev: RE: EPICS CA Interface for caQtDM and epicsqt Zai Wang
Next: RE: EPICS CA Interface for caQtDM and epicsqt Mezger Anton Christian (PSI)
Index: 2012  2013  2014  <20152016  2017  2018  2019
Prev: RE: epicsqt compile error Williams Jr., Ernest L.
Next: RE: epicsqt compile error Williams Jr., Ernest L.
