2012  2013  2014  <20152016  2017  2018  2019  Index 2012  2013  2014  <20152016  2017  2018  2019
Subject: RE: epicsqt compile error
From: "Williams Jr., Ernest L." <[email protected]>
To: Zai Wang <[email protected]>
Cc: "[email protected]" <[email protected]>, "Babbitt, Alisha" <[email protected]>, "Williams Jr., Ernest L." <[email protected]>
Date: Tue, 17 Mar 2015 00:02:11 +0000
Hi Zai,
The actual problem is the the epicsqt package uses two different variables for the same thing.
framework uses:
# The following QWT include path and library path are only required if
INCLUDEPATH += $$(QWT_INCLUDE_PATH)
But Applications uses:
$(QWTINCLUDE)
So, I set  "QWTINCLUDE"   to  "QWT_INCLUDE_PATH"
The Getting started Guide only talks about setting:   "QWT_INCLUDE_PATH"
Alisha will send out a diff file and patch for the changes we made.
Then you can consider them for inclusion into your next release.
Cheers,
Ernest
Sent: Monday, March 16, 2015 4:06 PM
To: Williams Jr., Ernest L.
Hi Ernest
You might mix up with caQtDM. They have different ENV variables for the same libs. It may be easy to use other PC or virtual box without caQtDM at start.
Then you check the make log msgs to see if any error.
Note: the below log complains caQtDM no qwt include path defined.
Cheers
Zai
Subject:
"Williams Jr., Ernest L." <[email protected]<mailto:ernesto_at_slac.stanford.edu>>
To:
"[email protected]<mailto:Andrew.Rhyder_at_synchrotron.org.au>" <[email protected]<mailto:Andrew.Rhyder_at_synchrotron.org.au>>
Cc:
"[email protected]<mailto:qti-talk_at_aps.anl.gov>" <[email protected]<mailto:qti-talk_at_aps.anl.gov>>, "Babbitt, Alisha" <[email protected]<mailto:ababbitt_at_slac.stanford.edu>>, "Williams Jr., Ernest L." <[email protected]<mailto:ernesto_at_slac.stanford.edu>>
Date:
Mon, 16 Mar 2015 16:24:22 +0000
Hi Andrew,
I definitely have QWT installed
I used QWT to actually build caQtDM.
[ernesto@icd-pc90626 qwt-6.0.1]$ env |grep QWT
QWT_INCLUDE_PATH=/afs/slac/g/lcls/package/qwt-6.0.1/include
QWT_ROOT=/afs/slac/g/lcls/package/qwt-6.0.1
However, when attempting to build epicsqt, I get the following error:
cd applications/QEGuiApp/ && make -f Makefile
make[1]: Entering directory `/afs/slac.stanford.edu/g/lcls/vol8/epics/R3-14-12-4_1-0/extensions/extensions-R3-14-12/src/epicsQt/epicsQt-R3-0-2/applications/QEGuiApp'
make -f Makefile.Release
make[2]: Entering directory `/afs/slac.stanford.edu/g/lcls/vol8/epics/R3-14-12-4_1-0/extensions/extensions-R3-14-12/src/epicsQt/epicsQt-R3-0-2/applications/QEGuiApp'
g++ -c -m64 -pipe -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -m64 -mtune=generic -D_REENTRANT -Wall -W -DQE_USE_CAQTDM -DQT_NO_DEBUG -DQT_SCRIPT_LIB -DQT_XML_LIB -DQT_GUI_LIB -DQT_NETWORK_LIB -DQT_CORE_LIB -I/usr/lib64/qt4/mkspecs/linux-g++-64 -I. -I/usr/include/QtUiTools -I/usr/include/QtDesigner -I/usr/include/QtCore -I/usr/include/QtNetwork -I/usr/include/QtGui -I/usr/include/QtXml -I/usr/include/QtScript -I/usr/include -IO.linux-x86_64/ui_headers -I. -Iinclude -I../../framework/widgets/QEWidget -I../../framework/widgets/QEForm -I../../framework/widgets/QELogin -I../../framework/data -I../../framework/api -I../../framework/common -I../../../../caQtDM/caQtDM-R3-8-10/caQtDM_Lib/src -I../../../../caQtDM/caQtDM-R3-8-10/caQtDM_QtControls/src -I -IO.linux-x86_64/moc -IO.linux-x86_64/ui_headers -o O.linux-x86_64/obj/main.o src/main.cpp        !
In file included from ../../../../caQtDM/caQtDM-R3-8-10/caQtDM_Lib/src/limitsStripplotDialog.h:45,
                 from ../../../../caQtDM/caQtDM-R3-8-10/caQtDM_Lib/src/caqtdm_lib.h:68,
                 from include/MainWindow.h:52,
                 from include/QEGui.h:32,
                 from src/main.cpp:27:
RE: epicsqt compile error Zai Wang
Prev: EPICS CA Interface for caQtDM and epicsqt Williams Jr., Ernest L.
Next: RE: EPICS CA Interface for caQtDM and epicsqt Williams Jr., Ernest L.
Index: 2012  2013  2014  <20152016  2017  2018  2019
Prev: RE: epicsqt compile error Williams Jr., Ernest L.
Next: RE: epicsqt compile error Zai Wang
