2012  2013  2014  <20152016  2017  2018  2019  Index 2012  2013  2014  <20152016  2017  2018  2019
Subject: RE: epicsQt-R3-1-0: Build Experience
To: "Williams Jr., Ernest L." <[email protected]>
Cc: "[email protected]" <[email protected]>, Lucas J Monteiro Carvalho <[email protected]>, "Babbitt, Alisha" <[email protected]>, Zai Wang <[email protected]>
Date: Tue, 9 Jun 2015 12:13:56 +0000
Hi Ernest
My mistake... the library is installed as well. All the more reason to have a look at your install output please.
Andrew
Sent: Tuesday, 9 June 2015 15:47
To: Andrew Rhyder
Cc: [email protected]; Babbitt, Alisha; Lucas J Monteiro Carvalho; Zai Wang; [email protected]; Williams Jr., Ernest L.; Szalata, Zenon M.
Subject: epicsQt-R3-1-0:  Build Experience
Hi Andrew,
How is it going?
Thanks to you and the team for releasing 3.1.0
I am now trying to build your new epicsQT package:  "3.1.0"
First I built caQtDM version 3.9.3
For the build, process I was able to set some environment variables according to your documentation.
I have attached the script that I source before the build :)
I was also looking for a make install
Also, I tried makepackage but that did not work.
For us,  epicsQT_TOP = $EPICS_EXTENSIONS/src/epicsQt/epicsQt-R3-1-0
========= Still need to copy the application binaries manually ===============
cd  <epicsQT_TOP>/applications/QEGuiApp/bin
cp qegui                      $EPICS_EXTENSIONS/bin/$EPICS_HOST_ARCH
cd  <epicsQT_TOP>/applications/QEMonitorApp/bin
cp qemonitor              $EPICS_EXTENSIONS/bin/$EPICS_HOST_ARCH
cd  <epicsQT_TOP>/applications/QEReadArchiveApp/bin
cp qerad                      $EPICS_EXTENSIONS/bin/$EPICS_HOST_ARCH
cd  <epicsQT_TOP>/applications/QEWidgetDisplayApp/bin
cp QEWidgetDisplay  $EPICS_EXTENSIONS/bin/$EPICS_HOST_ARCH
========= Still need to copy the framework libraries manually ===============
cd  <epicsQT_TOP>/framework/designer
cp libQEPlugin.so        $EPICS_EXTENSIONS/lib/$EPICS_HOST_ARCH
cp libQEPlugin.so        $EPICS_EXTENSIONS/lib/$EPICS_HOST_ARCH/designer
Below: Are the environment variables prior to build process:
[ernesto@icd-pc90626 epicsQt-R3-1-0]$ env |grep QE
QE_CAQTDM_LIB=/afs/slac/g/lcls/epics/R3-14-12-4_1-0/extensions/extensions-R3-14-12/lib/linux-x86_64
QE_TARGET_DIR=/afs/slac/g/lcls/epics/R3-14-12-4_1-0/extensions/extensions-R3-14-12
QE_FFMPEG=YES
QE_EPICS_BASE=/afs/slac/g/lcls/epics/R3-14-12-4_1-0/base/base-R3-14-12-4_1-0
QE_CAQTDM=/afs/slac/g/lcls/epics/R3-14-12-4_1-0/extensions/extensions-R3-14-12/src/caQtDM/caQtDM-R3-9-3
[ernesto@icd-pc90626 epicsQt-R3-1-0]$ env |grep QT
QTDIR=/afs/slac/g/lcls/package/Qt-5.4.1
CAQTDM_DISPLAY_PATH=/afs/slac/g/lcls/tools/caQtDM/display/Tests:/afs/slac/g/lcls/tools/caQtDM/display/iocAdmin
QTINC=/afs/slac/g/lcls/package/Qt-5.4.1/include
QTLIB=/afs/slac/g/lcls/package/Qt-5.4.1/lib
CAQTDM_DISPLAY=/afs/slac/g/lcls/tools/caQtDM/display
QT_PLUGIN_PATH=/afs/slac/g/lcls/package/qwt-6.1.2/plugins:/afs/slac/g/lcls/epics/R3-14-12-4_1-0/extensions/extensions-R3-14-12/lib/linux-x86_64:/afs/slac/g/lcls/package/Qt-5.4.1/plugins
Cheers,
Ernest
RE: epicsQt-R3-1-0: Build Experience Williams Jr., Ernest L.
Prev: RE: epicsQt-R3-1-0: Build Experience Andrew Rhyder
Next: RE: epicsQt-R3-1-0: Build Experience Williams Jr., Ernest L.
Index: 2012  2013  2014  <20152016  2017  2018  2019
