2012  2013  2014  <20152016  2017  2018  2019  Index 2012  2013  2014  <20152016  2017  2018  2019
Subject: RE: epicsQt-R3-1-0: Build Experience
To: "Williams Jr., Ernest L." <[email protected]>
Cc: "[email protected]" <[email protected]>, Lucas J Monteiro Carvalho <[email protected]>, "Babbitt, Alisha" <[email protected]>, Zai Wang <[email protected]>
Date: Tue, 9 Jun 2015 11:53:14 +0000
Hi Ernest
Can you copy the output from make install for me?
I have tried downloading epicsqt 3.1.0 onto a reasonably clean environment and after a build 'make install' installs the executables, but not the library. I haven't had more that a cursory glance to find the problem yet, but I'll dig deeper tomorrow. My install is different enough to your experience however (in that it at least installs the executables) that I'd like to see your install output if possible please.
Regards
Andrew
Sent: Tuesday, 9 June 2015 15:47
To: Andrew Rhyder
Cc: [email protected]; Babbitt, Alisha; Lucas J Monteiro Carvalho; Zai Wang; [email protected]; Williams Jr., Ernest L.; Szalata, Zenon M.
Subject: epicsQt-R3-1-0:  Build Experience
Hi Andrew,
How is it going?
Thanks to you and the team for releasing 3.1.0
I am now trying to build your new epicsQT package:  "3.1.0"
First I built caQtDM version 3.9.3
For the build, process I was able to set some environment variables according to your documentation.
I have attached the script that I source before the build :)
I was also looking for a make install
Also, I tried makepackage but that did not work.
For us,  epicsQT_TOP = $EPICS_EXTENSIONS/src/epicsQt/epicsQt-R3-1-0
========= Still need to copy the application binaries manually ===============
cd  <epicsQT_TOP>/applications/QEGuiApp/bin
cp qegui                      $EPICS_EXTENSIONS/bin/$EPICS_HOST_ARCH
cd  <epicsQT_TOP>/applications/QEMonitorApp/bin
cp qemonitor              $EPICS_EXTENSIONS/bin/$EPICS_HOST_ARCH
cd  <epicsQT_TOP>/applications/QEReadArchiveApp/bin
cp qerad                      $EPICS_EXTENSIONS/bin/$EPICS_HOST_ARCH
cd  <epicsQT_TOP>/applications/QEWidgetDisplayApp/bin
cp QEWidgetDisplay  $EPICS_EXTENSIONS/bin/$EPICS_HOST_ARCH
========= Still need to copy the framework libraries manually ===============
cd  <epicsQT_TOP>/framework/designer
cp libQEPlugin.so        $EPICS_EXTENSIONS/lib/$EPICS_HOST_ARCH
cp libQEPlugin.so        $EPICS_EXTENSIONS/lib/$EPICS_HOST_ARCH/designer
Below: Are the environment variables prior to build process:
[ernesto@icd-pc90626 epicsQt-R3-1-0]$ env |grep QE
QE_CAQTDM_LIB=/afs/slac/g/lcls/epics/R3-14-12-4_1-0/extensions/extensions-R3-14-12/lib/linux-x86_64
QE_TARGET_DIR=/afs/slac/g/lcls/epics/R3-14-12-4_1-0/extensions/extensions-R3-14-12
QE_FFMPEG=YES
QE_EPICS_BASE=/afs/slac/g/lcls/epics/R3-14-12-4_1-0/base/base-R3-14-12-4_1-0
QE_CAQTDM=/afs/slac/g/lcls/epics/R3-14-12-4_1-0/extensions/extensions-R3-14-12/src/caQtDM/caQtDM-R3-9-3
[ernesto@icd-pc90626 epicsQt-R3-1-0]$ env |grep QT
QTDIR=/afs/slac/g/lcls/package/Qt-5.4.1
CAQTDM_DISPLAY_PATH=/afs/slac/g/lcls/tools/caQtDM/display/Tests:/afs/slac/g/lcls/tools/caQtDM/display/iocAdmin
QTINC=/afs/slac/g/lcls/package/Qt-5.4.1/include
QTLIB=/afs/slac/g/lcls/package/Qt-5.4.1/lib
CAQTDM_DISPLAY=/afs/slac/g/lcls/tools/caQtDM/display
QT_PLUGIN_PATH=/afs/slac/g/lcls/package/qwt-6.1.2/plugins:/afs/slac/g/lcls/epics/R3-14-12-4_1-0/extensions/extensions-R3-14-12/lib/linux-x86_64:/afs/slac/g/lcls/package/Qt-5.4.1/plugins
Cheers,
Ernest
epicsQt-R3-1-0: Build Experience Williams Jr., Ernest L.
Prev: RE: edl2ui - Byte and ChoiceButton mapped Williams Jr., Ernest L.
Next: RE: epicsQt-R3-1-0: Build Experience Andrew Rhyder
Index: 2012  2013  2014  <20152016  2017  2018  2019
Prev: epicsQt-R3-1-0: Build Experience Williams Jr., Ernest L.
