<19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Limits on CA message size?
Date: Tue, 17 May 94 15:14:54 -0500
>>> Note that some clients like dm carefully keep only one connection per IOC.
>>> Others may not.  Again, Jeff and/or Andy can confirm what the demand is
>>> for each instance of a sequencer:  It uses CA but not TCP/IP, therefore,
>>> it may be smart enough to not need the buffer.
>> Why is not CA responsible for this junk?  Why should the user programs
>> have to worry about it?
>> If CA handled this problem itself, we would have this problem solved in one
>> single place... once and for all.
>Within one UNIX process CA opens only one TCP/IP virtual circuit to each
>IOC communicated with. The problem is that some applications create
>additional independent UNIX processes to manage additional process
>variables. These applications may end creating duplicate TCP/IP
>circuits.
We know that.  But if the CA client uses the CA library to deal with the
socket operations, why can't it decide if a new one is needed or not for
each of the PV names?  Does it not already know where its sockets are
going to?
--John
Prev: Re: Limits on CA message size? Jeff Hill
Next: camacLib update Johnny Tang
Index: <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Problems with GDCT greene%denali.UUCP
