Subject: |
Reflections on a Reflective Memory Device Interface |
[email protected] (Bob Dalesio) |
Date: |
Fri, 27 May 94 09:05:01 MDT |
There are several problems in the current addressing scheme that certainly
need to be handled. The one that we have been dealing with the longest
concerns having too little information to pass between the database and the
device drivers to effectively configure and address them. As stated before,
this causing the driver writer considerable pain when adding a new I/O bus,
such as CAMAC or Bitbus.
The reflective memory problem is more akin to the name space situation in
EPICS. Names are defined in many different databases, however, they must be
unique on the network. We currently report when more than one IOC responds
to a channel name request. (Does this go to logMsg so that it's available
to anyone analyzing the system performance?)
As we move to an ASCII database format that is loaded at IOC initialization,
more and more consistency checking is done at initialization. It may be that
this reflective memory scheme could be checked then.
A little excursion into a strawperson design:
Develop a reflective memory resource manager or set or routines that
allocates blocks of memory as named, logical address space. The addressing
in the database then become a logical name address pair (much like the
current address space). The first access to each address space would then
need to specify if it was the master (owned the logical name) or the slave
(used the contents of the logical space). The first reference to the name
device would allocate a fixed size logical device block (simplify the
initial implementation and address checking - it would be easier to do variable
sized if we had a better interface to the device layer). If it was the master,
then the reference would be successful. If it was the slave that first made thereference, then the device support would return failure and mark the record
as INVALID. This would allow control loops to "open" if the needed parameters
were not available. This handles the initialization of IOC's occuring at
different times. (What is the power up state of a reflective memory? The state
of all of the other memory that it is reflecting or does it propagate some
values into the other memories?) The conversion of logical name to physical
address would be in the reflective memory (hopefully this saves it when
any machine is up). Each logical address space should also have a heartbeat
to indicate that the master IOC, device driver, etc.. are still healthy.
The device support should also have a reboot hook that marks the logical
space over which it has control, as rebooting. As a first pass, logical
name space has these states; not defined, no master initialization, rebooting,
no heart-beat (dead - at least sick), healthy. If more than one IOC claims to
be master of a logical name space, this generates a logMsg alarm into the
system error logger.
End of returned message
----- End Included Message -----
Re: Logical Naming of Hardware Addresses Andrew Johnson
Re: Reflections on a Reflective Memory Device Interface winans
<1994>
2025
2026
<1994>
2025
2026
