Subject: |
Re: "The problem admits of no explanation...." |
[email protected] (Jeff Hill) |
Date: |
Wed, 8 Jun 94 11:45:56 MDT |
> In the dev system, everything seems to boot and operate normally. In the prod
> system, I get a large burst of "error interrupts" when the GPIB board is
> initialized or serviced. Seems simple enough. But there's more.
Perhaps you have some sort of interrupt vector collision. Here is how
to check:
1) load iocCore
2) run "veclist()" from the vxWorks shell
3) run "iocInit" from the vxWorks shell
4) run "veclist()" again from the vxWorks shell and look for collision
Perhaps there is a high network load and this is resulting in poor VME
interrupt throughput to the GPIB board. Perhaps "ifShow", "ipstatShow",
and "icmpstatShow" from the vxWorks shell will be useful. Also take a
look at the LAN LED on the 167's front panel for a rough indication
of the network load.
Try the following test to see if the network is involved:
1) load all objects and databases from the NFS server
2) disconnect the network cable
3) run "iocInit" from the vxWorks shell comparing the GPIB
driver init to past behavior.
Jeff
______________________________________________________________________
Jeffrey O. Hill Internet [email protected]
LANL MS H820 Voice 505 665 1831
Los Alamos, NM USA 87545 FAX 505 665 5107
"The problem admits of no explanation...." Bill Brown
VxWorks development machine Tony Carter, MIT Bates Linac
<1994>
2025
2026
<1994>
2025
2026
