<19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: A channel access problem probably due to something else.
Date: Wed, 12 Oct 94 15:40:00 -0500
>These records are all processed synchronously, so it appears that I
>don't need to mess with PACT.  Is this a reasonable assumption?
Yes.  This is true for synchronous records.
>Any pointers/suggestions/wild guesses will be greatly appreciated.
Going from periodic to passive _should_ not make any difference to the
driver.  I would make sure that a passive record that gets processed
due to a poke at the PROC field is working properly before embarking on
other fun things like CA links.
What you probably have is a spin in an IRQ handler... is the VME light
stuck on?  That would indicate that something is spinning on a value it
is getting from an IO board.  Do you have a VME backplane tracer?  I
have found them to be of great value at times like this.
--John
Prev: A channel access problem probably due to something else. Bill Brown
Next: [none given] Anthony F. Pietryla
Index: <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: epics Device Drivers Thomas Dean
