Subject: |
Re: devLib, locationProbe routine |
[email protected] (Jeff Hill) |
Date: |
Wed, 26 Oct 94 14:06:23 MDT |
> Am I right in thinking that the routine locationProbe in devlib returns
> SUCCESS to indicate that the given address does *not* respond to VME accesses of
> any size?
Correct.
> I presume the aim here is to indicate that this area of the memory
> map is currently not used.
Correct.
> It seems wrong
> to expect an error code (S_dev_addressOverlap) as the status return indicating
> success (ie board found), which is what I would have to do if I used the
> locationProbe routine.
This depends on what you are using locationProbe() for. Some VXI cards allow
their addresses in VME A24/A32 to be mapped dynamically. If we move a card
to an allocated address space then we must be certain that nothing already
exists in this space.
> Should I be using this in my driver to check that a board is present? The older
> drivers use vxMemProbe, which returns OK if something responds.
One of the original goals for devLib.c was that it should provide a wrapper around
vxWorks specific routines so that EPICS drivers would be more portable.
So we do want drivers to call a routine in devLib.c that provides a bus error
safe probe. Perhaps the return code names from this routine are badly chosen.
I am open to creating a new routine for 3.12 which addresses this issue.
Another goal of devLib.c was to detect address collisions and provide
address maps on demand. This functionality is provided by
devRegisterAddress() and devAddressMap().
> Are there plans to modify the existing drivers to use the devLib facilities?
Yes. The source in devLib.c was a product of the aborted EPICS RX
project. I suspect that there are very few drivers that actually use
it at this time. The first step should be to review the
devLib interface for EPICS V4. We should look carefully at virtual memory
issues, A16/A32/system RAM mapping conflicts (attn John Winans), and
OS independence.
Jeff
______________________________________________________________________
Jeffrey O. Hill Internet [email protected]
LANL MS H820 Voice 505 665 1831
Los Alamos, NM USA 87545 FAX 505 665 5107
Re: devLib, locationProbe routine Marty Kraimer
vxWorks mv167 BSP memory FAQ John R. Winans
<1994>
2025
2026
<1994>
2025
2026
