<19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CA library on the PC
From: [email protected] (Mark S. Engbretson (Bessrc-Cat))
Date: Mon, 5 Dec 94 11:52:18 CST
Jeff Said
>Initial port was done at LBL by Chris Timossi. I integrated the
>his changes + improved the general portability of the code for 3.12.
>This is in the latest 3.12 beta however the PC port needs to be
>retested.  Chris: are you still interested in testing the port?
>Perhaps Mike can fetch you a copy?
I have looked at the code a bit over the weekend . . . by any chance, could
you locate a makefile for the Windows build and make it available?
The compilers which I have access to are having some problems with the code
and I assume that most of this is probably due to defines wrongly defined,
assumptions that I am assuming wrongly, code that I am attempting to build
which should not be part of the windows CA library, or maybe even the chance
that I will have to change compilers.
Me
Prev: Re: CA library on the PC Jeff Hill
Next: pvget to an _output_ record Bill Brown
Index: <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
