1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: EPICS env parameters
Date: Fri, 6 Jan 95 11:37:45 MST
There are several places where the defaults for EPICS environment
parameters can be found. At first you find include/envDefs.h then you
discover that this is overwritten by src/libCom/epicsEnvParams.h. All
of this seems to be redundant (and inconsistent because not all of the
parameters are in epicsEnvParams.h).
I would prefer that we set the global default for each project from
an ASCII file and not by modifying source files - epicsEnvParams.h /
envDefs.h.
comments?
Jeff
______________________________________________________________________
Jeffrey O. Hill			Internet	[email protected]
LANL MS H820			Voice		505 665 1831
Los Alamos, NM 87545 USA 	FAX		505 665 5107
Prev: Epics release 3.12.Beta3 and the 4MB barrier Matthias Clausen DESY -MKV2/KRYK-
Next: Re: Bug in DM using long records? Deb Kerstiens
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: EPICS env parameters winans
