1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: 3.12 Makefiles
Date: Thu, 23 Feb 95 09:35:10 MST
What I'd like to see, and I can't do it because of a possible bug
in GNU Make, is to be able to set the sources and objects of
individual products in a clear way.
One of the only things I really missed about imake was its ability
to do this well.
I tried to use a syntax like the following with gnumake:
VPATH = ..
SRCS.prod1 = a.c b.c
OBJS.prod1 = a.o b.o
LIBS.prod1 = -lca -lCom
SRCS.prod2 = foo.c bar.c
OBJS.prod2 = foo.o bar.o
LIBS.prod2 = -lca
etc.
And I tried SEVERAL dependency rules to get the above to work.
If anyone wants to try to find a rule that works for the above,
go for it !
Matt ([email protected])
Prev: 3.12 Makefiles Andrew Johnson
Next: Last (?) word on PGP 415
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
