1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: 3.12 Makefiles
Date: Thu, 23 Feb 1995 12:45:25 GMT
I recently worked out a better way of doing lists within the Makefiles and the
CONFIG_EXTENSIONS (and CONFIG_BASE) inclusions.  The problem with the existing
method is that you can't comment out a line in the middle of a make variable
definition, so to remove one of the extensions or drivers you have to reorganise
the list completely and move the commented out line to the end.  Can we change
these files to use the += construct which gnumake 3.71 supports?  My favourite
example is a reorganised base/src/drv/Makefile.Vx, which looks like this:
# module_types starts the driver list
SRCS.c	:= ../module_types.c
OBJS	:= module_types.o
SRCS.c	+= ../drvAb.c
OBJS	+= drvAb.o
#Don't include At5Vxi driver
#SRCS.c	+= ../drvAt5Vxi.c
#OBJS	+= drvAt5Vxi.o
SRCS.c	+= ../drvBB232.c
OBJS	+= drvBB232.o
If you really wanted to, you could have a macro (or whatever they call them in
gnumake) which does both of these at the same time, then you'd only have to have
a single line in the Makefile for each driver.  Any comments?
- Andrew
          ,_}\_.        Andrew Johnson, Technology Division
         /      \       Royal Greenwich Observatory
 ~~~~~~~| ,--/;. )~~~~  Madingley Road, Cambridge, UK
    .,  |/  (/  U       Phone: +44 (0)1223 374823
  .`., /_\ . .          Email: [email protected]
     wwWWWww'           WWW: http://www.ast.cam.ac.uk/~anj/
Prev: [none given] greene%denali.UUCP
Next: RE: 3.12 Makefiles Matthew Needes
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: sf2db Nick Rees
