1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: R3.12 Environment Parameter system
Date: Tue, 14 Mar 1995 23:23:30 GMT
Encouraged by Steve Lewis' agreement that "things could be neater", and as I now
have the Beta9 release, I have implemented an improved system for Environment
parameter defaults.  It works like this:
A new configuration file, config/CONFIG_ENV contains *all* the default (site-
specific) values.  A new script bldEnvData scans the base/include/envDefs.h file
for all of the ENV_PARAM declarations, and combines these with the defaults to
create a header file envData.h in the libCom target directories.  envData.h is
#included by the envDefs.h file when ENV_PRIVATE_DATA is defined, and contains
all of the ENV_PARAM *definitions* with their defaults.  The whole process is
automated through the libCom Makefile.* so that changes to envDefs.h or
CONFIG_ENV will result in a rebuild of the envData.h file.
As a result, I have deleted base/src/libCom/epicsEnvParams.h and removed the
routine epicsSetEnvParams from libCom/envSubr.c and db/iocInit.c where it is
called.  This leaves a question - we don't really need INITHOOKafterSetParams
any more. Should it be removed, or left in?
Disadvantages: the vxWorks routine envShow now only displays those parameters
you set within the resource.def file or have changed by hand; before it also
gave the settings from epicsSetEnvParams().  However, epicsPrtEnvParams still
works as before.
CONFIG_ENV is interpreted using the Borne Shell /bin/sh so the settings are not
quite as free-format as they are with Makefile variables; you can't use spaces
inside the EPICS_ENV_PARAMETER=VALUE pair.
Advantages: Provided they were compiled with the same settings, the host tools
and IOC will always have the same defaults.  To change a site-wide default, you
only need to edit config/CONFIG_ENV and rebuild.
It would be trivial to create epicsPrtEnvParams at the same time as envData.h to
guarantee it would know about all the declared variables, but I haven't done
that yet.
Any comments?  Have I been wasting my time?
- Andrew
          ,_}\_.        Andrew Johnson, Technology Division
         /      \       Royal Greenwich Observatory
 ~~~~~~~| ,--/;. )~~~~  Madingley Road, Cambridge, UK
    .,  |/  (/  U       Phone: +44 (0)1223 374823
  .`., /_\ . .          Email: [email protected]
     wwWWWww'           WWW: http://www.ast.cam.ac.uk/~anj/
Prev: Work needing support Bob Dalesio
Next: beta release problems Marty Kraimer
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: R3.12 Environment Parameter system Steve Lewis
Next: CA for Windows NT Chris Timossi
