1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: beta release problems
Date: Thu, 16 Mar 1995 17:06:06 -0600
> From [email protected] Thu Mar 16 15:59 CST 1995
> Date: Thu, 16 Mar 95 13:59:16 PST
> From: [email protected] (Loren Shalz)
> To: [email protected]
> Content-Type> : > text>
> Content-Length: 872
> Marty,
> Converting from Epics R3.11.1 to R3.12.Beta8 I discovered the following:
> 1.	tsLocalTime() returns 0(the status from TScurrentTimeStamp) rather
> 	than S_ts_OK.
I found this also. It will be fixed in next beta release.
> 2.	With R3.11.1 I could call dbGetField() in the initialization routine
> 	of a subroutine record in order to get the SCAN field of the record
> 	in DBR_STRING format.  If I do that with R3.12.Beta8, iocInit
> 	reports
> 		Illegal Lock Set Lock Set out of range:dbScanLock
> 	and suspends.
> 	I have gotten around this by moving the call to the processing
> 	routine and testing to make sure I do it only once.  What I am
> 	doing is getting the scan rate out of the string and storing
> 	it in the H field for later use.
> 	I recall something about "locks" and "gets" being different in
> 	R3.12.  Is this related?
Yes. You can however you can use dbGet with exactly the same arguments
as dbGetField
> 	Are there routines available for getting field values in the
> 	initialization routine?
> Thanks,
> Loren
Prev: Re: R3.12 Environment Parameter system Andrew Johnson
Next: Alpha/OSF port and r3.12 Beta9 415
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Work needing support Bob Dalesio
