1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Retrieving the monitored values of Waveforms.
Date: Mon, 24 Apr 1995 16:43:45 -0500
> 	Has anyone added support for the retrieval of the monitored value
> of waveforms? I'm asking 'cause I'm doing archival of some ARCH records (which
> look like waveforms) under CaWave and from what I can see CaWave.pro, CaWave.c,
> and ultimately caevent.c doesn't support this. They support scalar PVs and
> lists of scalar PVs, not waveforms.
You are right, currently, the CaWave does not support the monitoring of the
waveform record.
> 	I really need to grab the value associated the monitor since the contents
> of the ARCH record will have changed on me (without monitors posting) if I
> grab the value from the IOC.
> 	Any help or pointers would be greatly appreciated! (I really don't want
> to rewrite parts of caevent.c right now).
> 	BTW, I'm using R3.12beta1.Gemini.
However, in the aps_wish ( a TK/TCL version of channel access) it supports the
monitoring of waveform record in HEX/BINARY/DECIMAL.  It is available as an
extensions tool. The usage of monitor of waveform can be found in the simple
document
      /usr/local/epics/extensions/doc/aps_wish.doc.
If the document does not mention the monitoring of waveform record, you need get
the new release epics/extensions.
An example of monitoring an waveform record 'chademowf2' in aps_wish is given below:
	aps_wish
	ezcasetmonitor chademowf2
	set WF(chademowf2)
The above 'set WF' command will print the current values of the wave from record.
Ben-chin
Prev: Retrieving the monitored values of Waveforms. mcgehee
Next: Re: Retrieving the monitored values of Waveforms. Ben-chin K. Cha
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
