Subject: |
Re: Retrieving the monitored values of Waveforms. |
[email protected] (Ben-chin K. Cha) |
Date: |
Mon, 24 Apr 1995 16:54:58 -0500 |
> Has anyone added support for the retrieval of the monitored value
> of waveforms? I'm asking 'cause I'm doing archival of some ARCH records (which
> look like waveforms) under CaWave and from what I can see CaWave.pro, CaWave.c,
> and ultimately caevent.c doesn't support this. They support scalar PVs and
> lists of scalar PVs, not waveforms.
You are right, currently, the CaWave does not support the monitoring of the
waveform record.
However, in the aps_wish ( a TK/TCL version of channel access) it supports the
monitoring of waveform record in HEX/BINARY/DECIMAL. It is available as an
extensions tool. The usage of monitor of waveform can be found in the simple
document
/usr/local/epics/extensions/doc/aps_wish.doc.
If the document does not mention the monitoring of waveform record, you need get
the new release epics/extensions.
An example of monitoring an waveform record 'chademowf2' in aps_wish is given below:
aps_wish
ezcasetmonitor chademowf2
set WF(chademowf2)
The above 'set WF' command will print the current values of the wave from record.
Ben-chin
Re: Retrieving the monitored values of Waveforms. Ben-chin K. Cha
<1995>
2025
2026
<1995>
2025
2026
