1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: More than 1 output link
Date: Wed, 24 May 95 13:10:25 -0500
>Does anyone know how to add more than 1 output link to a record?
Unless the record supports it, you will have to use something like the sequence
record.  It was designed to fetch values and then put them elsewhere (It has a
group of link pairs in it.)  It was also designed to allow a delay between each
transfer if you want... zero is an allowable delay.
So then, you could point each of the inputs to the same place and all the outputs
to... whereever and use a delay of zero, and get the effect you describe.
--John
Prev: Postscript Documentation Stefan Hippler
Next: Problem with MVME167-02B boards Mark Rivers
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: More than 1 output link Andy Foster
Next: Re: More than 1 output link Steve Lewis
